Old 03-27-2011, 04:39 PM   #16
Professional
Ruud furnace will not start
that is a carrier, not a ruud and looks nothing like a ruud. a ruud 80% inducer would be very similar to this
just saying lets be accurate!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-27-2011, 04:55 PM   #17
I'm Your Huckleberry
Grief.
Doc Holliday is offline   Reply With Quote
Old 10-13-2011, 11:42 PM   #18
I have a Rudd furnace model # OGOG-05EAUER the furnace will not ignite. this does not have a standing pilot. Also the blower and furnace fan do not want to shut off unless I manually turn off the switch. I verified gas supply by taking off drip leg.All electrical connections are tight. It worked fine last cold season and has not been tampered with. I am hoping its' a quick fix I can do like thermostat. Need help Thanks
MOJOHOUND is offline   Reply With Quote
Old 10-13-2011, 11:44 PM   #19
Originally Posted by Doc Holliday View Post
Grief.
I like that. but i need help
Old 10-14-2011, 06:51 AM   #20
Professional
You need to check the control board for a flashing LED diagnostic code.
IT IS WHAT IT IS
Gas Furnace Won't Stay Running / Thermostat Set High To Start _scott HVAC 6 03-23-2011 08:27 PM
trane TUE060 furnace won't start jkolo HVAC 3 11-04-2010 07:29 PM
Trane XE-80 - Furnace No Start Dirkasaurus-rex HVAC 2 10-25-2010 03:23 PM
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 22 01-16-2010 12:34 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
