Ruud Furnace Super Quiet 80 Troubleshooting - HVAC - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 05:35 PM   #1
ruud furnace super quiet 80 troubleshooting
I had a lennox furnace for 20 years no problems well it died. I had a new ruud furnace super quiet 80 installed last year what a piece of junk! I have had the HVAC Technician out 4 times two times last year so fare 2 more times this year and it is not even January yet. It will only get up to 60-65 degrees It will only flame up for 10 to 15 seconds. The Technician was out last week and it started working. I don't know what they did but we are back to square one it is only getting up to 60-65. What should I check? Because this is getting old!! I would not recomend a Rheem/ruud furnace to anyone.
Sillynic is offline   Reply With Quote
Old 12-18-2010, 06:47 PM   #2
An old Tradesmen
Rewards Points: 6,132
It ain't the furnace. Its the tech/company your using.
What error code is it flashing.
Old 02-13-2011, 08:58 AM   #3
i am having similar issues with mine. I replaced the board and a few other components and same problem. I called in a pro who initially told me may need new board and something else. my furnace is only 5 years old.
diy4me2 is offline   Reply With Quote
Old 02-13-2011, 09:24 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,140
What exactly are the issues you are having? Is it giving any error codes? look in the viewing window in the lower door. codes should be listed in the wiring diagram on the back of the lower door. Do not remove the door B4 reading the codes (flashing leds) or they get erased.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Ruud Furnace issue grubslinger HVAC 16 09-14-2011 01:13 AM
Perplexing problem, Ruud furnace jbarker HVAC 43 01-20-2010 01:03 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
