Ruud Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 11:45 AM   #1
Ruud furnace problem
I have Ruud gas furnace 75k btu that runs great without fresh air pipe connected but runs intermitently when the pipe is reattached..Pipe clear of blockages..<15 ' of pipes. Any idea what is happening
wayne z is offline   Reply With Quote
Old 11-06-2010, 12:03 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,288
Pressure switch failing. Ventor fan slowing down. Need a manometer to check the draft thru the furnace and rating of the switch. May have an inlet screen where the pipe attaches to the furnace/burner box with debris in it slowing down the draft. Some Carriers and Lennox do.
Old 11-06-2010, 07:45 PM   #3
Could also be recirculating the exhaust into the intake. Have seen that happen more then a few times due to someone cutting off the vents or placing something in front of them to block the view of the pipes.
Payne furnace problem Laughingchi HVAC 26 05-24-2015 03:59 PM
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Another Keeprite Electric furnace problem lrad Electrical 0 10-18-2010 12:24 PM
Ruud Furnace Problem patiofurniture HVAC 1 09-23-2009 07:14 PM
ruud furnace problem troubled1 HVAC 4 10-18-2006 04:14 PM
