-   -   Ruud furnace problem (http://www.diychatroom.com/f17/ruud-furnace-problem-85952/)
wayne z 11-06-2010 11:45 AM
I have Ruud gas furnace 75k btu that runs great without fresh air pipe connected but runs intermitently when the pipe is reattached..Pipe clear of blockages..<15 ' of pipes. Any idea what is happening
yuri 11-06-2010 12:03 PM
Pressure switch failing. Ventor fan slowing down. Need a manometer to check the draft thru the furnace and rating of the switch. May have an inlet screen where the pipe attaches to the furnace/burner box with debris in it slowing down the draft. Some Carriers and Lennox do.
Marty S. 11-06-2010 07:45 PM
Could also be recirculating the exhaust into the intake. Have seen that happen more then a few times due to someone cutting off the vents or placing something in front of them to block the view of the pipes.
