RUUD Furnace Not Working Blower Runs - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2008, 08:43 PM   #1
RUUD furnace not working blower runs
In December we had problems with the furnace, came home to no heat but blower running. Had a friend check it out and thought it was the circut board replaced it and furnace worked for 20 days. Came home tonight to house at 58 and blower running again. Can only get blower to shut off at the breaker box. With weekend temps at 0 I need heat again soon. Any help available?
ddeatrick99@hotmail.com is offline   Reply With Quote
Old 01-16-2008, 09:45 PM   #2
biggles's Avatar
something is making that fan come on with the heat call and no burner...down at the unit terminal strip jump R to W1...W2 if you have it..this is to prove your problem is not the stat, but down at the furnace???if your not getting a spark for pilot or any clicling after you toggle power back up it is the burner side do the jump first....and see the reaction..also you can use the emergency swicth you should have to kill the fan...don't hesitate to call somebody or make plans to run your cold water to keep it from breaking...if it gets that bad do the hot water also put the valve on the HWH to pilot and to keep the heater from maintainig the water running on the hot waterr side.
Old 01-16-2008, 09:55 PM   #3
Union HVAC Tech.
Some Ruud/Rheem models go to steady fan when the igniter fails. Unplug the igniter and check for resistance.
bigMikeB is offline   Reply With Quote
Ruud Furnace issue grubslinger HVAC 16 09-14-2011 12:13 AM
blower runs, with no heat captjack HVAC 6 12-14-2010 02:15 PM
replaced furnace blower now breaker issue Kurr HVAC 5 01-25-2007 09:22 PM
Furnace Blower Problem SGecko HVAC 2 09-27-2006 10:16 AM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
