Old 10-18-2009, 12:29 AM   #1
Default Ruud furnace issue on upgrade board and flame sensor
let me start by off by saying i have a Ruud Silhouette natural gas furnace. model UGLG-07eauer. made in 1994. In june 2009 i had the circuit board(Protech 62-24084-82) and blower motor replaced. The problem i have is that the electric glow igniter lights up and ignites the gases. The gases will stay lit for 5 secs or so then shut off. So after reading i get the picture that it would be the flame sensor. I cleaned it with steel wool but it made no difference. so i thought maybe i need a new one but no one is open on the weekend. But after doing more researching it shows that the updated circuit board might need the remote flame sensor kit. But since mine already has a flame sensor, the wire needs to be re-route from the white wire.
If there is no flame sensor then you will need to install one, run the supplied wires per the instructions to the new 3 light control board. ( 2 Green & 1 Amber Light)
If there is an existing flame sensor, check the wiring, if it is spliced into one of the Hot surface Ignitor wires it will need to be disconnected and then run the supplied wires per the instructions to the new 3 light control board. ( 2 Green & 1 Amber Light)
Flame sensors Installed with 2 Light Boards was spliced into the Ignitor wires.
Flame sensors Installed with 3 Light Boards must wire back to the control board.
ALL Rheem HOT Surface Ignition Furnaces should be equipped with a Remote Flame sensor.
has anyone done this? instead of buying the remote flame sensor kit since i already have the sensor. i should be able to reroute the wire to the board connector. any guidance is appreciated.
rubberman is offline   Reply With Quote
Old 10-18-2009, 10:33 AM   #2
old pro
You don't need to change anything as it already has been done and has worked. Clean the face of the burner the sensor sits in front of with fine emory paper or clean steel wool. Make sure the circuit board is secured properly as it needs to be grounded properly or it won't sense the flame. The new board should have a diagnostic set of LEDs. You may have to remove the lower door and put duct tape on the door switch temporarily. Then fire it up and see if a code appears. You would need the instruction sheet with the board for the code. Post it here and someone may know it or find it on the net yourself. Check the porcelain of the flame sensor for cracks. If cracked or brown/black in color replace it.
Old 10-18-2009, 11:12 AM   #3
well i wired that flame sensor to the spot on the board as the instructions said and it works now. The flame led light comes on now which it never did before.
Old 10-18-2009, 11:21 AM   #4
old pro
Good for U.
Old 10-18-2009, 03:46 PM   #5
instead of buying the RHeem/Ruud remote flame sensor kit that includes the wire, connectos and that. i think i might go to radio shack and get the same stuff. be cheaper and work the same.
Old 10-18-2009, 04:30 PM   #6
old pro
Post a pic of the burner area of your furnace. Sounds confusing what you are saying. The older Rheems and Colemans used the HSI hot surface igniter as the flame sensor also. Had an extra white wire spliced into the HSI wire. The system was crap. Then they went to the standard flame sensor like everyone uses. The "remote" kit was nothing more than a flames sensor and a bracket. I think you have that already and don't need it. It is INCREDIBLY important that the flame sensor be mounted exactly where they intend it with the proper kit or you could blow up your house. The flame failure response time is less than 1 second and if you have the sensor in the wrong spot KABOOM and I am deadly serious.
This is nothing to fool around with if you don't understand it. You could be liable if someone gets hurt.
Old 10-18-2009, 09:10 PM   #7
ok here it is. the glow igniter is on the right. the red wire behind the black gas pipe is where the flame sensor is and its mount in its bracket. in the top left corner you see the 2 white wires plus the red flame sensor wire come together in that pigtail connector. the instriuctions say to remove the red wire from that pigtail and run that to the board cause this new board monitors that different than the old revision board.
Old 10-18-2009, 09:34 PM   #8
old pro
Now I feel better. Just follow their instructions and you should be okay and use their parts.
Old 10-18-2009, 10:16 PM   #9
Here is another view showing the flame sensor mount.
Old 10-18-2009, 10:25 PM   #10
old pro
Looks good to me and the same as their newer furnaces. You should remove the burner on the far left and clean its face with fine emory. A flame sensor is not a sensor. It is a live probe with AC voltage which jumps thru the fire and converts to DC (rectifies). Then feeds thru the burner back to the board in microamps. A dirty burner prevents current flow.
Old 11-18-2009, 04:01 PM   #11
Default Same furnace
Hey Rubberman, I need to install the same board. However there are two teminals missing from the new board. Any way you could post a pic of the control board. Unemployed right now and a tech wants $450 to replace the board . I can buy one for less than 200. However there are 2 extra wires and I don't know were they would go.
On the old board they are labled 24vac and com , grouped together.
Anyone else know or have the instructions for installing this board. Would like to see before ordering it, and its getting very cold in here.
needy is offline   Reply With Quote
Old 11-18-2009, 07:16 PM   #12
Easy to follow instructions come with the new board needy. If I remember correctly those go through a 9 pin connector instead of directly to the board. Everything you need comes in the box,just follow the instructions.
More On This Topic
In this clip, we're going to talk about the proper way to remove and replace a rear wheel anti-lock brake sensor on a late model Ford Explorer. In this step, we're going to talk about the proper way to re-connect your rear wheel anti-lock wheel speed... Read More »
Add Rum to Bananas Foster
Add Rum to Bananas Foster by Expert Village
Hi, I'm Chef Rainer Wickel, and I'm here today with ExpertVillage.com. Well, we've taken the bananas out the mixture, and now we need to get ready to make our final sauce. Now, what we're going to do here is we're actually going to be adding a (1/4... Read More »
In this clip, we are going to talk about the proper service procedure in order to diagnose remove and replace your vehicles starter solenoid. In this step we are going to talk about what starter solenoid is and the proper way to diagnose the command wire... Read More »
In this next segment, I want to talk to you about the trailer hitch lighting. The trailer has lights so you've got to be able to plug it in to your vehicle lights. You have brake lights, turn signals, so you can warn the people behind you when you're... Read More »
The terminals on your car battery are an essential component for the function and life of your engine. Ensuring the battery terminals are connected properly will help your engine run more efficiently and extend the life of the battery. These steps... Read More »
Ruud Achiever 90 Plus - no Flame Snesor mmn7957 HVAC 2 10-14-2009 10:49 PM
Luxaire furnace flame out Tuckrb HVAC 10 03-19-2009 10:52 PM
Miller G5RA furnace flame sensor problem mpit52 HVAC 3 01-16-2009 12:30 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 03:55 PM
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 5 11-07-2008 06:52 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
