Ruud Furnace Intermittent Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 12-31-2009, 10:25 AM   #1
dbh
Ruud Furnace intermittent problem
Ok this is driving me crazy...furnace works fine for a day then stops working all together...reset the power to the furnace and it starts to work again...checked the board and i get one solid green light and a blinking green light when the thermostat is calling for heat but nothing else happens until i reset the power to the unit.
Any ideas? I have replaced all limit switches last year...control board two years ago. The furnace is a 1993 i believe.
Thank you
db
dbh is offline   Reply With Quote
Old 01-02-2010, 11:39 AM   #2
dbh
Ok 50 ppl viewed this post and not one person has a clue what might cause this problem...hmm think i might be in the wrong place.
Old 01-02-2010, 12:17 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
Read the error code info which may be on the back of one of the doors or in the electrical diagram. Post the model and serial # and pics of the unit with both doors off so we can recognize it.
Old 01-02-2010, 08:11 PM   #4
dbh
Ok can not find the model number but here are some pictures.
Ruud Furnace intermittent problem-img00155-20100102-2029.jpg   Ruud Furnace intermittent problem-img00156-20100102-2030.jpg   Ruud Furnace intermittent problem-img00157-20100102-2031.jpg   Ruud Furnace intermittent problem-img00158-20100102-2031.jpg   Ruud Furnace intermittent problem-img00159-20100102-2032.jpg
Old 01-02-2010, 08:25 PM   #5
i'm not familiar with this make of furnace, but from your pics, i can see where the flame rod attaches to the burner, but can't see it IN the flame. follow the black wire under the burner, and see the rod is in the flame. if it is, take it out with a 1/4 driver and clean it with fine steel wool ( not sandpaper).
hvac benny is offline   Reply With Quote
Old 01-02-2010, 08:29 PM   #6
dbh
Benny thanks for your reply...I did that last season, does this have to be done every year?
Old 01-02-2010, 08:36 PM   #7
dbh
Here are some of the flame sensor.
Ruud Furnace intermittent problem-img00162-20100102-2132.jpg   Ruud Furnace intermittent problem-img00163-20100102-2132.jpg
Old 01-02-2010, 08:45 PM   #8
it looks like it could use a cleaning. not a bad idea to do this before the heating season every year, but just lightly.
Old 01-02-2010, 08:50 PM   #9
dbh
Would this cause the unit to work intermittently like that? The furnace will work fine for sometimes days and then it will get cold in the house and i will notice that it isn't kicking on...but soon as i reset the power to the furnace it works fine again.
Old 01-02-2010, 08:55 PM   #10
The board will lock out if flame is not sensed. Clean the front of the burner also, that's half of the flame proving operation.
Old 01-02-2010, 09:41 PM   #11
Question
OK. Leave and then come back! You'll realize that there are none better than this one. If you provide the correct and pertinent information, I will bet you that your problem will be resolved. One or more of the experts who frequent this blog will have an answer! (No matter what) Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 01-02-2010, 09:47 PM   #12
Apparently yes! BTW. You have a ton of technical information on the inside wall of the furnace. Why didn't you take a close (readable) picture of those data?!??
Old 01-02-2010, 09:56 PM   #13
dbh
I thought it was too SP but after 50 views and not one reply i thought that it might just be...I have had nothing but problems with this Ruud furnace since i bought this house 5 years ago...as i said in my first post i have replaced just about every part that you can replace in this furnace and i am still having problems with it...now if cleaning the burners and flame sensor fixes this i will be very surprised and delighted at the same time. I will post my findings after i clean everything tomorrow....and i agree with you Don't Drink and Drive.
Old 01-02-2010, 10:00 PM   #14
dbh
I have trouble shot this unit since day one SP and yes you are correct there is a ton of technical information on the inside of this unit and it still does not tell me what is causing this intermittent problem...if i was just a limit switch that opened up or a fuse or loose wire or whatever no problem i wouldn't even be posting this problem.
Old 01-02-2010, 10:34 PM   #15
Sometimes the flame sensor will cause the furnace to lock out completely, and other times it's just dirty enough to be an intermittent problem.
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 12:01 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Carrier Furnace Problem Boats1183 HVAC 1 11-11-2008 06:41 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 02:04 PM
