RUUD Furnace Fan Won't Run On 'Auto' - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 10:43 AM   #1
Question
RUUD Furnace Fan Won't Run on 'Auto'
I have a fairly old RUUD electric furnace that still works well. However when I switch to 'Emergency Heat' the fan will not come on. I have to turn the fan to 'On' instead of 'Auto' to get it to run. It runs fine on auto when not switched to Emergency Heat. Any idea of the problem / fix ? Thanks...
eggerldave is offline   Reply With Quote
Old 12-04-2010, 10:48 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
is your back up heat gas or electric.... could be stat, but more likely a relay in furnace
hvactech126 is offline   Reply With Quote
Old 12-04-2010, 10:56 AM   #3
It is electric. I replaced a relay (Essex 184-20103-301L) with another, though not exact relay of the same specs (it had one more connection post (6) that I didn't use since it didn't exist on the original relay.
Is there any chance it is the thermostat ? Both lights (EMERG HEAT and AUX HEAT( light up when I switch to 'Emergency Heat' but the fan doesn't come on. As soon as I swith back to 'Heat' the fan comes on.
Thanks...
Old 12-04-2010, 11:02 AM   #4
AKA HVACTECHFW
with it in e-heat, check for 24v between green wire from stat and c or common @ furnace. IF you have 24v then it is relay, if not then probably stat
Old 07-10-2011, 05:08 PM   #5
In same boat
I am trying to find the same replacement part. Where did you find the ESSEX 184-20103-301L? Thanks!
bharrisii is offline   Reply With Quote
Old 07-11-2011, 11:21 AM   #6
Rewards Points: 1,574
You might try:
http://www.perfectpaysupply.com/3591...0103-333a.html
Give them a call and see if the last L in your part number means anything.
bob22 is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Perplexing problem, Ruud furnace jbarker HVAC 43 01-20-2010 01:03 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Furnace does't start when Fan is 'auto' stepicz HVAC 2 10-18-2005 07:10 AM
