Ruud Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2011, 09:50 AM   #1
Ruud furnace
Hi everyone thanks for the valuable info u gave me last time. The furnace is working ok for the most part just had one more question. Sometimes when u turn the furnace off with thermostat and wait several hours then turn it back on it will start right up and run and the house will get up to temp like it should then it will shut down fine but then starts right back up and runs for bit it will do this and then after 3 or 4 times of that it will functions properly and once in a great while it will do it again any ideas what might be going on thanks a lot Joe. model number is ruud ugpj-07eauer
joseph1122 is offline   Reply With Quote
Old 12-02-2011, 10:03 AM   #2
What is the reading on the flame sensor?
harleyrider is offline   Reply With Quote
Old 12-02-2011, 11:57 AM   #3
how
Rewards Points: 1,070
I wonder if you have a ghosting thermostat problem. The next time that this is happening I'd check to see if your thermostat is calling for heat again.
how is offline   Reply With Quote
Old 12-02-2011, 12:35 PM   #4
Thanks guys how do i check the flame sensor am i doing a ohms reading through it or checking voltag.e to it thanks a lot for the info Joe
Old 12-02-2011, 02:49 PM   #5
biggles's Avatar
if your not over heating from the last cycle and your basically hearing the fan come on 2 or 3 times might be left over heat buildup from the last cycle...keep in mind the fan is the last thing to run when the stat satisfies....especially if you have a bi-metal disc sensing heat-X(fan-on) and needs to cool it off...fan cycle is 100% controlled from the furnace and not the stat in the heating mode...
Old 12-02-2011, 03:30 PM   #6
Thanks but the fan run after the furnace shuts down but then as soon as it stops then the other little motor up top that is hooked to presure swithch starts up and then furnace relights but it only does this now and then usually when u just rurn T stat on warms house to temp shuts down and starts right back up and then 3 or 4 times then it works fine except once in a while it will do it again then straighten up thanks for all the info. Joe
Old 12-02-2011, 04:03 PM   #7
biggles's Avatar
The Inducer Draft Motor(IDM) will only run if the stat is calling you mighht be doing an anticipation to make set point.but a s i said if your not overheating its the stat that is causing this random run...but the IDM is the first thing to run on a call from the stat....before anything else happens you have to proof air into the burner thu the presssure switch as seen proof of draft you get spark ...pilot proof of pilot...main gas. how digital is your stat is it set for the type of heat your running...check settings
Old 12-02-2011, 10:42 PM   #8
Thanks the stat is not digital my girl friend said it is not that old year or so
Ruud Silhouette II Furnace Problem komobu HVAC 17 01-17-2016 07:46 PM
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 03:13 PM
Ruud Furnace intermittent problem dbh HVAC 29 01-04-2010 08:52 AM
Ruud furnace won't ignite kickinmhl HVAC 4 04-19-2009 11:19 AM
