Ruud Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 09:12 AM   #1
Ruud furnace
Hey everyone i am having an issue with our natural gas furnace it is a Ruud model ugpj-07eauer the problem is it wont ignite. The ignitor does not glow but i pulled it out of the unit hooked power to it and it came right on. Put it back in the furnace,then on circuit board there is a 6 prong plug checked for power there i have power going to the fan but no power on the terminals that feed the ignitor. Is there some that sends power to the ignitor a reason i dont have power going to those terminals or is the board bad. also i am getting code 3 not sure what that mean board number is 62-24268-03 thanks Joseph
joseph1122 is offline   Reply With Quote
Old 11-30-2011, 09:18 AM   #2
I am not 100% sure of that code but I think its a limit fault.... see this thread Lennox 80UHG3 - Combustion Air Blower doesn't spin see post # 5 for an explanation of open limits...
harleyrider is offline   Reply With Quote
Old 11-30-2011, 03:26 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 150
ruud error codes are in SMALL print on the wiring diagram.
Old 11-30-2011, 07:53 PM   #4
Thanks to all furnace is fixed.Open limit switch bought new limit switch and furnace seans to run fine now waiting for it to shut reach temp and shut down thanks again to all thanks. from Joseph
Old 11-30-2011, 08:02 PM   #5
Rewards Points: 582
good to hear joe....still would be nice to know what caused the failed switch...are filters changed on a regular basis...is the a/c coil dirty.... these can cause the limit to open and close to much druing cycling and cause failure......
Old 11-30-2011, 08:11 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 150
limit control should last the life of the furnace and never have to open/work if there is proper airflow. do a temp rise check. there is a rating ie: 35-65 degF on the model # sticker. stick a cooking thermometer 1-2 ft downstream from the plenum and subtract the return or house temp to see the rise. run unit for 5-10 mins.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (11-30-2011)
Old 12-01-2011, 03:42 AM   #7
An old Tradesmen
Rewards Points: 7,816
As Yuri said. You have a problem somewhere, or the limit wouldn't have opened.
Check for a dirty A/C coil, dirty air filter, and or dirty secondary heat exchanger if its a condensing furnace. Also check for blocked or closed registers/grilles.
Look to see what speed the blower is set to.
Old 12-01-2011, 08:47 AM   #8
Thanks guys for the great info i will check those things to see if i can find a reason why it failed sure is nice to have some heat thanks again. Joe
Ruud Silhouette II Furnace Problem komobu HVAC 17 01-17-2016 06:46 PM
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Ruud Furnace intermittent problem dbh HVAC 29 01-04-2010 07:52 AM
Ruud furnace won't ignite kickinmhl HVAC 4 04-19-2009 10:19 AM
