Ruud Furn Clunk - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2008, 03:40 PM   #1
Ruud Furn Clunk
My Ruud Furnace clunks just before the main blower turns on. Sometime the clunk a de clunk, clunk is prettey bad. Sounds like a solinoid not working properly. Any suggestions where to look?
Jimmy C is offline   Reply With Quote
Old 12-07-2008, 04:01 PM   #2
Sounds just like a bad U-joint on a car. In other words, a loose coupling or setscrew.
Old 12-07-2008, 04:47 PM   #3
Ruud Clunk
No not like car U joint more like electrical solenoid not fully actuating. Is there a temp sensor that may be malfunctioning?
Old 12-07-2008, 06:17 PM   #4
Maybe a relay mount is loose.
Old 12-07-2008, 06:35 PM   #5
Maybe a humidifier solenoid.
SKIP4661 is offline   Reply With Quote
Old 12-08-2008, 08:37 AM   #6
Or it could be the main gas control. There are two valves that have to open simultaneously.
hvaclover is offline   Reply With Quote
Old 12-08-2008, 07:16 PM   #7
Ruud 90
Thanks all for the diagnoses. I will check for the min. gas press. valve. That sounds more like what It could be.
Old 12-08-2008, 09:15 PM   #8
Ruud Acheiver 90 Gas Furnace 32FordCoupe HVAC 32 11-20-2008 09:04 PM
RUUD gas furnace - flame will not stay on frostyfreeze HVAC 1 11-07-2008 11:25 PM
Ruud furnace-no heat nomdeplume HVAC 12 12-11-2006 02:44 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 09:33 PM
