#1 |
Ruud filter?
Okay, this is really lame, but I cannot for the life of me find the filter on our ruud UGTA-07EMAES model.
![]() Here is a pdf of the spec sheet: http://www.adamsheatingandcooling.co...ugta-specs.pdf Where the heck is it? Can someone look at the photo on page 2 and give me a clue? Thanks! |
#2 |
Ruud filter?
would be external to the furnace? (ie P6 external filer rack accessory)
| The Following User Says Thank You to bbo For This Useful Post: | greenteam (01-27-2013) |
#3 |
Ruud filter?
It's either at the start of the return air duct(filter grill) or end of the return air duct (filter rack).
| The Following User Says Thank You to Marty S. For This Useful Post: | greenteam (01-27-2013) |
#4 |
Ruud filter?
I don't see anything like that. There is a Honeywell electronic air cleaner, but that is different. The lower door on the ruud says "filter access door," but when I open it (and the top one in the spec photo) I really can't find anything that seems remotely like a filter.
#5 | |
Ruud filter?Quote:
when the pdf is open, do a control then F then type filter in the search box. you will be searching through the document for the word filter. |
#6 |
Ruud filter?
You wouldn't have a disposable filter and an electronic air cleaner. The honeywell EAC is your filter. Make sure to clean the EAC cells and pre-filters at least once a month.
#7 |
Ruud filter?
Thanks for the information everyone. I am glad I posted the Honeywell info and thanks for asking the questions that got to the answer. The Honeywell it is, so now I have the answer.
I thought I was crazy. Well, I am, but not for this reason! |
#8 |
Ruud filter?
You can clean the HW 'filters' or elements with a garden house, if it's not too cold outdoors. Note direction of how each comes out. Otherwise, dishwasher or bathtub (with towels down).
I used a backpack blower (air only) when it was very cold. If you use water of any kind to clean and elements are not completely dry, you will hear a crackle noise (burning ozone) until dry. This is normal. Clean after any construction when airborne wallboard compound is sanded. |
| The Following User Says Thank You to diyorpay For This Useful Post: | greenteam (01-27-2013) |
| Display Modes | |
| Old Payne filter size | Granger72 | HVAC | 4 | 12-13-2012 12:14 AM |
| Inline water filter for built-in fridge (water supply line on top) | Druidia | Appliances | 5 | 03-10-2012 01:05 AM |
| ruud silhouette 2 furnace filter | mk00 | HVAC | 1 | 02-26-2012 08:54 AM |
| Inground pool and filter...HELP! | Blpavlovich | Building & Construction | 2 | 06-09-2011 06:49 PM |
| furnace filter fit?? | Doug7852 | HVAC | 4 | 04-01-2011 11:45 AM |
