-   -   Ruud filter? (http://www.diychatroom.com/f17/ruud-filter-170243/)
greenteam 01-27-2013 10:27 AM
Ruud filter?
Okay, this is really lame, but I cannot for the life of me find the filter on our ruud UGTA-07EMAES model.
:whistling2:
Here is a pdf of the spec sheet:
http://www.adamsheatingandcooling.co...ugta-specs.pdf
Where the heck is it? Can someone look at the photo on page 2 and give me a clue?
Thanks!
bbo 01-27-2013 10:34 AM
would be external to the furnace? (ie P6 external filer rack accessory)
Marty S. 01-27-2013 11:20 AM
It's either at the start of the return air duct(filter grill) or end of the return air duct (filter rack).
greenteam 01-27-2013 11:21 AM
I don't see anything like that. There is a Honeywell electronic air cleaner, but that is different. The lower door on the ruud says "filter access door," but when I open it (and the top one in the spec photo) I really can't find anything that seems remotely like a filter.
bbo 01-27-2013 11:44 AM
there is something called a permanent filter n it.
when the pdf is open, do a control then F
then type filter in the search box. you will be searching through the document for the word filter.
Marty S. 01-27-2013 05:29 PM
You wouldn't have a disposable filter and an electronic air cleaner. The honeywell EAC is your filter. Make sure to clean the EAC cells and pre-filters at least once a month.
greenteam 01-27-2013 06:14 PM
Thanks for the information everyone. I am glad I posted the Honeywell info and thanks for asking the questions that got to the answer. The Honeywell it is, so now I have the answer.
I thought I was crazy.
Well, I am, but not for this reason!
diyorpay 01-27-2013 06:32 PM
You can clean the HW 'filters' or elements with a garden house, if it's not too cold outdoors. Note direction of how each comes out. Otherwise, dishwasher or bathtub (with towels down).
I used a backpack blower (air only) when it was very cold.
If you use water of any kind to clean and elements are not completely dry, you will hear a crackle noise (burning ozone) until dry. This is normal.
Clean after any construction when airborne wallboard compound is sanded.
