RUUD Experts Wanted! - HVAC - Page 5 - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 10:38 AM   #61
I just got off the phone with a RUUD/Rheem representative. He believes that installing a TEV will improve the efficency of the heat pump and may also help or eliminate the accumulator frost up. His expertise with the RUUD line of equipment gives me the motivation to have a tech go ahead and swap out the fixed orifice with the TEV. He said that the EER rating will also increase as well. I will report back and let you know how it goes....
carlb7 is offline   Reply With Quote
Old 10-10-2011, 10:40 AM   #62
JJboy's Avatar
Originally Posted by carlb7 View Post
Well I guess that means you don't have the answer to my question? The reason for my post is to determine if replacing parts will make a difference.
No I'm not, I'm not an engineer of this unit. You've got the manufacturer's information which accumulator used for each metering device (Orifice and TXV). I'm guessing you only want to discuss theories. You've got a lot opnion in this 3 years...get the tools and start changing parts like we do in lab.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-10-2011, 10:42 AM   #63
JJboy's Avatar
don't forget to replace the accumalator.
Old 10-10-2011, 07:36 PM   #64
If you go with the txv then you wont need an accumulator. The txv should stop the frosting problem.
Master of Cold is offline   Reply With Quote
Old 10-10-2011, 09:13 PM   #65
Thanks Master of Cold, I will report back after the installation!
Old 10-27-2011, 08:13 PM   #66
Update !!!
Well the TEV has been installed and the frostup has ceased. The temperature does not dip at the upflow any longer and the compressor sounds the smoothest it has ever sounded! If anyone can explain why this is the case then go for it. I will relax and feel the warmth.
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 03:32 PM
Ruud heat pump high pressure switch mikethe ductman HVAC 3 07-28-2010 07:00 AM
Ruud help tritrinh HVAC 3 12-05-2009 11:47 PM
Help: All I wanted to do was replace a light switch MicahPDX Electrical 5 07-04-2009 01:13 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
