Ruud Central Air Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 07-18-2011, 07:12 PM   #1
jwz
Hello,
Here is the story. Last night my power went out. Long story short my main breaker was tripped and my Central Air Unit was not working. After troubleshooting I found my fuses were shot on the unit. Replaced them this morning. The Fan on the unit was blowing and air was coming out of the vents "not cold air". Then I had a service tech do a diagnostic. He advised the capacitor was shot. He advised that replacing the capacitor should fix my problem. I just replaced the capacitor and nothing has changed. The unit is still blowing air but not cold air. What could be the problem? The temperature by me is 90+ and I have two little girls who are sweating in this hot house. Any suggestions is greatly appreciated. By the way the unit is 20 years old.
-Jason
jwz is offline   Reply With Quote
Old 07-18-2011, 07:58 PM   #2
An old Tradesmen
Rewards Points: 6,906
Could be the compressor windings are open.
This is a somewhat common situation when a tech only does diagnostics. There can always be other problems, that don't show until the first bad part is replaced.
Old 07-18-2011, 08:32 PM   #3
jwz
tech came out and said the compressor is shot, now on to finding a new unit, any suggestions i have a 3 ton unit now. was quoted 1500 for a new one installed
Old 07-18-2011, 10:04 PM   #4
An old Tradesmen
Replace both units. Don't use the old indoor coil over, unless they can show your an AHRI rating for it matched to your new outdoor unit.
Old 07-18-2011, 10:08 PM   #5
jwz
Whats your opinion on a York Guardian unit?
Old 07-18-2011, 10:32 PM   #6
vln
Underwriter
Don't.
Get another Rheem. Much, much better.
vln is offline   Reply With Quote
Old 07-18-2011, 10:35 PM   #7
jwz
I am having a 3 ton unit replaced by my cousin for a great price $900 for a york guardian. I read some terrible reviews online over at Furnacecompare.com York is rated almost dead last and on the site they have recent customer testominals. They have amana, rudd, rheem, american standard, tempstar, trane, weatherking, carrier, goodman, ducane in that order to name a few and york last. Should I be worried?
Old 07-18-2011, 10:37 PM   #8
jwz
Vin some people on her are saying its not so much the brand that matters its the installer, what do you think? do you really think rheem is that much better than york?
Old 07-18-2011, 11:10 PM   #9
vln
Underwriter
Yes, after I read the reviews on furnacecompare as well, and personal experience.
Old 07-19-2011, 04:21 AM   #10
An old Tradesmen
Most reviews you'll find on furnaces and central A/C's are not reliable. Because most of the problems stem from a bad/improper install.
The installation is more important then the brand.
Old 07-19-2011, 11:51 AM   #11
jwz
Thanks "beenthere" I have read that on here also, that the install is more important than the unit. With that said, being that my old ruud unit is 20 plus years old, do I need to replace the indoor coil cover? What is the proper procedure when replacing an old unit like this? I am leery my relative is going to do a good job? What questions should I be asking him about the install? Thank you guys for all of your help, it is greatly appreciated!
Old 07-19-2011, 12:03 PM   #12
jwz
This is a summary of the work to be done in an estimate from a local HVAC company? Does this look right?
REMOVE OLD CONDENSER
SET GIBSON 3 TON CONDENSER ON NEW PAD
BRAZE LEAK CHECK & VACUUM LINESET
HOOK UP ELECTRIC TO DISCONNECT & WHIP
PERFORM START UP
Old 07-19-2011, 12:12 PM   #13
30 year tech
hvac122's Avatar
You should replace the indoor coil at the same time. If you don't match the system there is no way to tell what efficiency or tonnage you may end up with.
hvac122 is offline   Reply With Quote
Old 07-19-2011, 12:19 PM   #14
I'm Your Huckleberry
Rewards Points: 2,270
Remove and replace any and all refrigerant liquid line driers. That needs to be on there as well. If no filter driers are there to begin with, add them. One low side and one high side. Best place for the low side is outside close to the condenser on the suction line (low pressure vapor line) and the best place for the high side (high pressure liquid line) is a few feet before the evaporator coil on the inside of your home.
Filter driers catch any possible debri in the lineset, just liike a fuel filter on a car. Mandatory for compressor burn outs.
Doc Holliday is offline   Reply With Quote
Old 07-19-2011, 12:25 PM   #15
jwz
Thanks Doc, do you also recommend replacing the indoor coil?
Tags
ruud central air unit
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 04:07 AM
Central Air Unit Not Functioning supitch15 HVAC 9 05-02-2010 08:50 PM
Central Air Unit is freezing up, all fans working rebuildergirl HVAC 3 06-08-2009 08:42 PM
Central air unit throwing breaker joycet Electrical 4 08-20-2008 08:35 PM
Can a fireplace heat through my central unit? Randell Tarin HVAC 4 02-13-2008 03:48 PM
