RUUD Central Air Blowing Warm Air - HVAC - DIY Chatroom Home Improvement Forum
Old 07-05-2013, 07:08 PM   #1
RUUD central air blowing warm air
Hi,
I have central air unit for the second floor. Few weeks ago fan on the outside unit stopped spinning and on the second floor it was blowing hot air.
I called tech and he came and changed capacitor chat after hour the same thing happened. Tech came over and said it was fan. he changed fan and when he measured pressure on hi side it was too high and low side was too low. He put bigger motor and it looked like pressure became within range 150/200.an
When unit stops I can hear whistle sound from compressor. Low side is not too cold while high side very hot.
He told me that it is probably blockage inside coil and the whole coil needs to be changed ~2k for 2T.
Can someone point me to the right direction? Thanks in advance for any help.
Bob.
bobdelon is offline   Reply With Quote
Old 07-05-2013, 09:31 PM   #2
An old Tradesmen
Rewards Points: 7,818
Probably dirty indoor and outdoor coils. Clean them.
central air not blowing cold air sherryl77 HVAC 3 08-26-2011 03:49 PM
Ruud Central Air Unit jwz HVAC 30 07-21-2011 04:21 PM
Goodman central air and heat blowing fuses DannyR HVAC 13 05-29-2011 06:21 PM
Central AC Blowing But Not Cooling? agent1320 HVAC 9 10-26-2010 06:20 PM
Central heating unit not blowing air SoCalRailFan HVAC 8 12-27-2008 07:32 PM
