Ruud Achiever 90 Plus - No Flame Snesor - HVAC - DIY Chatroom Home Improvement Forum
Old 10-04-2009, 08:34 PM   #1
Ruud Achiever 90 Plus - no Flame Snesor
2000 Model UGRA-10EZAJS - furnace turns on and lights for 8 seconds - then shuts off - repeats 3 more times and then locks out - no yellow LED on the IFC board whenthe flame is lit - tried cleaning the flame sensor - tried replacing the flame sensor - checked ground continuity- checked continuity between flame sensor and IFC - checked voltages on IFC - all at 24 VAC - checked polarity of 115 VAC - checked 115 VAC to chassis ground - checked igniter - replaced igniter - checked continuity igniter to IFC - replaced IFC twice (model is a 2008 "A" version versus original 1999 "plain" - tried new 115 VAC line direct from circuit breaker box - tried grounding to burner frame - cleaned burners (not really dirty) - checked limit switches - no fault lite codes on IFC - no signs of damage - removed thermostat connections and jumpered IFC terminals - still no flame sense - ideas??
mmn7957 is offline   Reply With Quote
Old 10-04-2009, 09:02 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 140
Check the inlet gas pressure to the furnace with a manometer. I had a intermittent problem once where the gas co regulator was dying. Would build up pressure and as soon as the gas valve opened would lose pressure/fade out. If you don't have a manometer get the gas co to send a tech out as it is their responsibility to provide you with a steady supply of gas. If you have propane then you need a propane tech and a manometer and check your tank/needs to be at least 1/4 full. Check for a steady 24 volts to the gas valve. The valve may be malfunctioning also. Usually they are good for about 12-13 yrs before acting up.
Old 10-14-2009, 08:49 PM   #3
I am having the exact same problem as you, no flame sence at all .. I have check all the items you listed plus the gas pressure I am a trained tec on Ruud/ Rheem furnaces and have run accross this problem before.. and have always been able to get it figured out, not this time spent 5 hrs thus far and cant get. Please reply if you have figured any thing out Thanks for any hel you can offer.
budlane1 is offline   Reply With Quote
RUUD Achiever 90 plus small blower won't turn off tahoeboy50 HVAC 5 09-14-2010 02:32 PM
Ruud Achiever 90+ not Satisfying Thermostat Tico HVAC 4 12-26-2008 10:20 AM
RUUD gas furnace - flame will not stay on frostyfreeze HVAC 1 11-07-2008 11:25 PM
