Ruud Achiever 80 Won't Run - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 04:36 PM   #1
Ruud Achiever 80 won't run
Ruud Achiever 80 furnace/A/C won't start. Nothing works, including the blower. I found that the regular light-style external switch in the attic that supplies power had been brushed into a position halfway between On-Off while moving junk around. I turned the switch ON, checked the breakers, but the system is completely inoperative. The thermostat clicks, still can't turn fan or A/C or heat on.
Do I need to reset the unit somehow? I can't see how to open the side panels on the furnace box near where the wiring and 24VDC line enter.
JJR2 is offline   Reply With Quote
Old 12-04-2010, 07:18 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
That switch may be broken. They fail from old age too. Need to see if you are getting 110 volts thru it with a voltmeter or electrician/tech buddy.
Old 12-05-2010, 10:45 AM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Also check if there is a low voltage fuse that is open in the furnace
hvactech126 is offline   Reply With Quote
RUUD Achiever 90 plus small blower won't turn off tahoeboy50 HVAC 5 09-14-2010 02:32 PM
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 02:32 PM
Ruud heat pump high pressure switch mikethe ductman HVAC 3 07-28-2010 06:00 AM
Ruud Achiever 90 Plus - no Flame Snesor mmn7957 HVAC 2 10-14-2009 08:49 PM
Ruud Achiever 90+ not Satisfying Thermostat Tico HVAC 4 12-26-2008 10:20 AM
