Rust On Gas Pipe Fittings In Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 09:03 PM   #1
Rewards Points: 20
In my basement I noticed some rust forming on the fittings of the gas line pipes. Don't want to this to eventually rust all the way through and end up with a big problem in terms of a gas leak. Can I just paint over it with some rust inhibiting paint or do I need to properly prep it first? Why is the rust only on the fittings and not on the pipe itself, different materials?
diyourselfer is offline   Reply With Quote
Old 02-10-2013, 09:07 PM   #2
Rewards Points: 12,812
It's not going to rust through. Steels going to rust. If it makes you feel better paint them safty yellow, that's the color code for a gas pipe.
Old 02-10-2013, 09:10 PM   #3
Roofmaster
Rewards Points: 2,172
Completely Normal, unless there is no pipe dope. Hard to tell with these pics. Focus? Whats to the right that looks like AB? The fittings are raw Iron pipe, the pipe has a coating on it. This is nothing to worry about at all unless you plan on living for 500 years or so.
Old 02-10-2013, 09:12 PM   #4
Roofmaster
Safty Yellow? Is that like Fur injun red?
Old 02-10-2013, 09:26 PM   #5
Rewards Points: 20
Updated the images with closer shots. Looks like they are unpainted fittings.
Old 02-10-2013, 09:31 PM   #6
Rewards Points: 406
Paint the fittings if you like but you should address the too tall moisture content of the basement air that caused the rust.
Old 02-10-2013, 09:43 PM   #7
Those fittings were probably that rusty the day they were installed.
hvac benny is offline   Reply With Quote
Old 02-11-2013, 08:09 AM   #8
Rewards Points: 406
My mistake. I assumed from the wording in the OP this was a concern that is getting worse.
Apollo fittings with copper pipe Coolboy55 Plumbing 7 07-27-2012 09:51 PM
Small Schedule PVC Pipe & Fittings Zekester Plumbing 2 07-26-2012 11:39 PM
Old kitchen Pipe drips water into basement when it rains Sammyc53 Remodeling 7 08-10-2011 10:54 AM
framing around drain pipe in basement griffinst Carpentry 5 03-25-2011 07:34 AM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 02:29 PM
