Runs Constantly - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-06-2013, 04:14 PM   #16
Rewards Points: 70
Originally Posted by beenthere View Post
No, its confusing.
But it may mean that the 4 ton air handler has a VS blower that is over coming the under sized duct work problem. And the 3 ton air handler had a standard blower, that could over come the under sized duct work.
Which would mean the problem was the duct work, and not the A/C size. So if you had them fix the duct work instead of just putting in a larger A/C. You would have good cooling and lower cooling bills.
PS: A hood can easily be off by 10% or more.
Understand, numbers were closer and better wit 4 ton.
Dang I wish you were in Houston! You are right the units put in are variable. At that phase, the house was built so changing the duct would really have been crazy!
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 06-06-2013, 04:38 PM   #17
An old Tradesmen
Rewards Points: 7,402
A static pressure check/ESP. Should be done to see what pressure the blower is working against. Too high tends to shorten the life span of a VS blower motor/module. If its real high, might want to get a module repair kit from Zebra.
Old 06-06-2013, 04:45 PM   #18
Rewards Points: 70
Funny you should say that, we had the upstairs go out about 4 years ago and had to replace the motor. But upon inspection, there was a capacitor that blew so we thought it was because of bad weather. I did just recently replace the capacitor after seeing that repair kit online. Actually found a post on the internet and bought the capacitor for less than 5 bucks I believe delivered.
Now I have a backup!
Old 06-06-2013, 11:10 PM   #19
An old Tradesmen
Your welcome.
A/C runs almost constantly and never gets to set Temp tyhorstman HVAC 21 08-14-2012 10:38 PM
Circulator pump runs constantly mikenri HVAC 6 12-20-2011 08:58 AM
Blower fan runs constantly epowerfan HVAC 65 12-06-2011 06:57 AM
need help/advice with a blower motor that runs constantly in a old bryant GetYourShineBox HVAC 0 07-27-2010 06:29 PM
inducer fan runs constantly tibsmandu HVAC 3 11-29-2009 11:12 AM
