Running Flexible Beside Metal - HVAC - DIY Chatroom Home Improvement Forum
Old 03-30-2009, 12:32 PM   #1
Hello!
Is it OK to run a flexible duct along side a metal duct? I'm installing a heat/light/vent unit in a basement bathroom and just want to make sure that I'm not creating a potential fire hazard if the ducts were to be touching each other. I don't think so...but just want to clear the question out of my mind!
Thanks for your help!
Mark
mlb115 is offline   Reply With Quote
Old 03-30-2009, 01:07 PM   #2
Remodeling Contractor
no problem Ducts do not get that hot.
Old 03-30-2009, 07:36 PM   #3
Thanks Bob! I was just concerned that the heat from the metal duct (at least during winter) might cause some problems with the flexible duct.
Mark
Old 03-30-2009, 11:24 PM   #4
kennzz05 is offline   Reply With Quote
Old 03-31-2009, 08:00 AM   #5
Originally Posted by kennzz05 View Post
LOL! Well, my concern is...if the metal duct gets hot from the air when the furnace is on...would there be any heat transfer/fire issues if there is a flexible duct laying right on top of and/or touching the metal duct?
Mark
Old 03-31-2009, 11:14 AM   #6
An old Tradesmen
Rewards Points: 7,814
Your furnace discharge air temp shouldn't be high enough to start a piece of paper on fire(roughly 460F).
Let alone transfer enough heat to another pipe to start a fire else where.
Old 03-31-2009, 12:23 PM   #7
Are you thinking of using those plastic flexible ducts?
If this is a duct for the bath exhaust go with a smooth rigid metal duct. Also, slope it towards the outside in case you get condensation building up inside it...another reason to avoid flex duct with ridges. You can also insulate it. Just my preference.
Mazz is offline   Reply With Quote
Old 04-02-2009, 07:49 PM   #8
Nope...it's aluminum. This is for a basement bathroom that will get more sink & potty use than shower use.
Thanks for the assistance everyone!
Old 04-03-2009, 09:51 AM   #9
A nice extra is a timer switch. Smell will linger in the room after you leave, so it's nice to have the fan running an extra 5 minutes or so after to clear out the odor.
Of course it's not necessary if you can remember to come back later and turn off the fan.
Old 04-03-2009, 09:59 AM   #10
Moisture too, since this is what the fan is designed for. Now it CT we are required by code to use a timed switch for the fan and it needs to be tied to the light so it will always get used.
Old 04-03-2009, 10:05 AM   #11
Is that for commercial? Seems strict for residential.
Old 04-03-2009, 10:14 AM   #12
for residential. Want to be assure to limit mold Cold here and one does not open the window to ventilate a bath during the winter.
hard metal vs. flexible ducts katea HVAC 4 05-18-2008 08:23 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Flexible metal corner bead? Worth using? yummy mummy Building & Construction 3 11-15-2007 06:09 PM
