Running Ducts In The Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 01:37 PM   #1
running ducts in the basement
Hello. I'm finishing my basement and I am getting ready to do the heating. Is there an easy way to run ducts down the walls? Also the permit says that I will need to have a high and low return vent. And configuration of air in the mechanical room. It will be about 1000sq ft finished and 250 sq ft in the mechanical room. Thanks
osucrna is offline   Reply With Quote
Old 03-02-2012, 02:29 PM   #2
there are no "short-cuts", if that is what you are asking.
hvac5646 is offline   Reply With Quote
Old 03-02-2012, 02:59 PM   #3
Nope not wanting to do a short cut I just don't know how to run a duct from overhead joist down a 2x4 studded wall to have the vent near the floor. Most basements I see have the vents on the ceiling but I would rather have them near the floor
Old 03-02-2012, 04:24 PM   #4
Return duct or supply? Supply duct will need wall stack ducting. Return can use the empty stud space without a metal duct inside it.
The high and low vents connecting the mechanical room and the larger space will not be hooked to any ducting. They're just to allow oxygen(combustion air) into the mechanical room for the fire .
Old 03-02-2012, 04:26 PM   #5
I wanted to run supply down the walls.
Old 03-02-2012, 04:34 PM   #6
Quick search came up with this.
http://www.alpinehomeair.com/related/Ductwork.pdf
Old 03-02-2012, 04:53 PM   #7
That is an awesome reference. Thanks
Old 03-02-2012, 06:27 PM   #8
MarginallyQualified
Rewards Points: 2,464
Verify this as the rules will vary.
Meanwhile... bookmark the Gray Metal website.
Once you see what is available... how to do things becomes simpler.
Tags
basement , return , supply
Running Generator Inside Garage or Basement AllanJ Electrical 26 07-04-2013 11:49 AM
Help with new duct work trunk running to attic from basement. coderguy HVAC 8 10-02-2011 10:22 AM
Running drains for basement bath jeerme Plumbing 4 03-04-2009 09:51 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Running Conduit in new basement framed walls tben Electrical 3 12-10-2004 11:14 PM
