Running Duct Through Limited Space - HVAC - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 08:55 AM   #1
Im installing a new trunk for my basement that will only be used for heating. I also plan on installing zone dampers and a bypass later on.
In one spot I cannot tap off the top of the trunk. I either have two ideas, one is to tap the side using an oval elbow and the other is to tap the bottom of the trunk.
If I tap the side using an oval elbow, do you think Ill be able to use the below fitting within the 5" space I have between the trunk and joist as shown below? I was planning on modifying the oval fitting and making tabs to install in the trunk or screw to the side of the trunk.
If I tap the bottom of the trunk I only have about 2" between the trunk and drywall. Is that do able?
casnj is offline   Reply With Quote
Old 12-18-2011, 10:21 AM   #2
HVAC Tech/ Browns Fan
With out being there to see it in person. I think you can do anyway you can.
Tator1076 is offline   Reply With Quote
Old 12-19-2011, 07:17 PM   #3
just wanted to see if anyone else has an other ideas
Old 12-21-2011, 03:49 PM   #4
could you cut a hole in the floor where you need above the trunk? Just a thought...
zipster is offline   Reply With Quote
Smell coming from all floor registers. John_W HVAC 10 08-07-2015 06:42 PM
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Limited access to furnace in crawl space diyfpm HVAC 0 07-23-2011 08:49 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 06:20 AM
Advice needed. Complete Furnace & duct replacement - asbestos ductwrap (crawl space) vestaviascott HVAC 11 03-10-2009 05:40 PM
