Running CSST Outside To Grill On Deck... - HVAC - DIY Chatroom Home Improvement Forum
Old 04-09-2007, 07:47 AM   #1
Rewards Points: 324
Running CSST outside to grill on deck...
Has anyone on this forum done this? I plan to run a line that will be split in my floor joists, one running to my garage heater, and one running through the outside wall under my deck and connect to a grill.
Should I add a shutoff right before it leaves the house?
tigerbalm2424 is offline   Reply With Quote
Old 04-09-2007, 08:07 AM   #2
Rewards Points: 1,088
You might want to install two shut off valves, one for each application.
handy man88 is offline   Reply With Quote
Old 04-09-2007, 09:17 AM   #3
Rewards Points: 324
Sounds like a plan. I have done a little research so far but I cant find anything for support while transitioning through an exterior wall. Is there any support connecting or specific way to put this through an exterior wall? Or just make a hole and caulk it?
Old 04-09-2007, 10:11 AM   #4
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
The manual from the gastite website will have all the specifics on what you describe.
From
http://www.gastite.com/homepage.php?pg=builders
links to
http://www.gastite.com/include/langu...IGuide2007.pdf
CSST is not a typical DIY endeavor. Most supply houses wont sell it to you w/o proof you have been trained and have a certificate to prove it and are a licensed plumber at least. That said, I have done one DIY CSST job after finding a local supplier that wanted my business. If you are really confident, have experience in gas pipe work, and are a good methodical DIYer, etc. I will tell you where you can get CSST online.
If it were me, I would install a shut off at the beginning of the line, before it splits, AND at at each appliance. The upstream one may not be required but its installation allows you to turn back on the gas to other appliances while you finish the new work.
Brik is offline   Reply With Quote
Old 04-09-2007, 10:21 AM   #5
Rewards Points: 324
From
links to
Thanks. I already ran copper line to the heater and its been working fine for a year or so. I decided now I would like to re-run the line in CSST and add a split so I can run a grill line. I already have a shutoff on the copper line where it T's off the main.
PM the online site if you wouldnt mind. I know Menards sells the CSST but Im not sure about the connections or if there are any stipulations to buy. Guess I'll find out.
Old 11-06-2008, 10:28 PM   #6
Home Inspector
If you have natural gas, copper gas line is not acceptable. Also, the line being tapped into must be larger than 3/4" diameter in order to tap two new lines.
Home Inspector is offline   Reply With Quote
Old 11-06-2008, 11:07 PM   #7
You have to have a shutoff at each device and a trap in each line.
It is all about supply.
A heater in the garage will probably take a larger line that the BBQ. If you split off a 3/4" line to the heater you might not have enough flow.
Anytime you have anything flowing in a pipe you will get non laminar flow which will cause increased back pressure. If it is long enough you could end up at 0 pressure.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
deck questions robphelan Carpentry 6 06-25-2006 07:42 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
deck walls maintenance Building & Construction 6 04-03-2005 11:37 PM
