Running A/c With Panel Off - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 01:23 AM   #16
REP
When done,the underside of the coil should look like the top of the coil that you have pictured above.
Biggles has a point though,if your coil is as bad as it is then you should also clean the blades on the blower squirl cage .
If you get the coil clean and the blower clean and keep a clean filter installed,your a/c should be able to blow the candles on your dining room tables out with nice cool air.
REP is offline   Reply With Quote
Old 03-04-2012, 06:46 AM   #17
biggles's Avatar
if the Op could rent that 2.5G pump sprayer and do the condenser cleaner ONE GALLON trick that thing would foam itself up bigtime,and get the inside dust/dirt within the coil..up to him.reson a pump sprayer is recommended a bottle sprayer won't get into the FINs but the PS will inject that light acid thru the FINs and give him maximm heat transfer with the approching cooling season....18F split(return vs supply) on a air handler like that would be typical...
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
More Sub Panel Questions rdkng07 Electrical 6 05-25-2011 09:46 AM
Help/Suggestions Running Cat5e Acroos Room To New Panel darveaux Electrical 6 02-28-2011 03:12 AM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 01:43 AM
Passing wire to another panel theatretch85 Electrical 5 09-21-2009 12:09 AM
