Running A/C Lines In A Wall - HVAC - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 12:59 PM   #1
running A/C lines in a wall
Newbie to the site. Installing air handler in my attic. Would like to run the line set inside the exterior wall until it reaches near ground level. Unable to find any internet info (pros or cons). Curious to know, is it a possible code violation. If not, should I be concerned with condensation, and if so, how to deal with it.
3 ton unit
line set approx. 35' long (20' to be in wall)
Thanks in advance for any and all help.
Regards,
Jules
JulesB is offline   Reply With Quote
Old 01-19-2011, 02:16 PM   #2
HVAC Contractor
Running lineset inside exterior wall is common practice here in Georgia, the suction line should already be insulated and I don't see an issue with sweating.
1acman is offline   Reply With Quote
Old 01-19-2011, 05:35 PM   #3
Rewards Points: 1,214
As long as it is insulated well and there are no joints hidden in the wall it should be OK.
COLDIRON is offline   Reply With Quote
Old 01-19-2011, 05:51 PM   #4
newtech's Avatar
Rewards Points: 164
I would put a blocker plate in front of it b-4 the drywall went up. Would hate to see you sink a nail or screw into it... Other than that, if it is well insulated, I don't see a problem.
newtech is offline   Reply With Quote
Old 01-19-2011, 05:56 PM   #5
Good Idea NEW long time no hear. Signed the wonderful and great S------. Take care. Iron.
Old 01-19-2011, 06:38 PM   #6
newtech's Avatar
Rewards Points: 164
Just would hate to see an " oops " after the drywall went up.
Talk to you on the other site
Newtech
Old 01-19-2011, 07:36 PM   #7
Thanks for the replies! I'm you're classic "get in over your head" DIYer, and have never been exposed to this situation before. I figured it wasn't a problem, but thought I'd check. I don't think "sweating" will be a problem, especially since it's a north facing wall.
Will definitely install blockoff plates.
Thanks!
Jules
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 02:55 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Running Electical plug behind wall burdman Electrical 2 04-20-2007 11:15 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
