Running But Still Not Cooling Off - HVAC - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 09:00 PM   #1
running but still not cooling off
came home from work today and the furnace was running but central air was not. fuse was tripped reset and couple min. tripped again.looked at it and there was bare wires arced to the unit.cutout frayed wire and reattached.
it will stay on but now the house isnt cooling off staying around 80+ but everything is running.not very cool air been 2hr and still running and no cooler ????
its a lennox furnace model C23-41WFC-1
lennox value series 10ACB condensing unit
wd45gto is offline   Reply With Quote
Old 08-03-2011, 09:02 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
is the large copper line from the outdoor unit cold and sweating?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-03-2011, 09:04 PM   #3
no
it is not,almost warm
Old 08-03-2011, 09:06 PM   #4
AKA HVACTECHFW
possibly low on charge. Because the house is so warm from not running today you are really noticing now how well it is NOT working. Check your air filter too.
IT IS WHAT IT IS
Old 08-03-2011, 09:07 PM   #5
so what do i do now ?
Old 08-03-2011, 09:08 PM   #6
AKA HVACTECHFW
not much YOU can do other than call a PRO. Check your air filter.
IT IS WHAT IT IS
Old 08-03-2011, 09:10 PM   #7
air filter good ,thanks for your help
Cooling capacity relation with air temperature. Samart HVAC 2 06-23-2011 07:39 PM
Running cat5 wire over ventilation / heating ducting ajtool General DIY Discussions 7 06-11-2010 12:45 PM
Wiring a Ruud RGTK-06E series furnace for 2-ton cooling bolo_invictus HVAC 3 01-25-2010 03:24 PM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 09:56 AM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 07:03 AM
