Running Air Handler In Winter - HVAC - DIY Chatroom Home Improvement Forum
Old 01-27-2009, 04:53 PM   #1
running air handler in winter
I have brand new ac system with accuclean filters. My question is does it make sense to run the system air handler in circulate -- fan only mode ( fan will run approx 35% of the time) during the winter to get the accuclean to do its job????? I have hydronic baseboard heat---- Boston , Mass area. THANKS
wmmurphy is offline   Reply With Quote
Old 01-27-2009, 06:14 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 128
If you have allergies, like clean air then run it. If not then don't.
Old 01-27-2009, 07:52 PM   #3
An old Tradesmen
Rewards Points: 7,808
If the air handler is in the attic/inconditioned space.
It will increase your heating bill.
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 09:48 AM
Sump pump running as much as 20 times per day Shpigford Plumbing 7 06-23-2008 09:33 AM
Air Handler Fan Sporadic Sammy HVAC 5 05-18-2008 05:30 PM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 07:03 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
