Old 12-05-2011, 03:20 PM   #1
Rudd furnance
my Rudd furnance wont turn on. I checkd the thermastat and that seems to be working. It clicks but wont start. There is gas flow cause the pilot is on. It was working on friday and I turned down the heat before Ieft my house and when I came back and turned the temp to 70 it wouldent turn back on.. Any sugestions on getting it back working???
Chevygirlaz is offline   Reply With Quote
Old 12-05-2011, 06:53 PM   #2
REP
Rudd furnance
Could be a lot of things but you might want to check the front cover on the furnace.That cover holds in a safty switch and if the cover is loose or not on just right the safty switch will kill the furnace.
REP is offline   Reply With Quote
Old 12-05-2011, 07:01 PM   #3
Rudd furnance
if you set stat to heat and the pilot is on and it clicks sounds like you have power because it is clicking it woulden't be if no power.....can you get picture of unit with door off...
Carrier furnance earl kay HVAC 2 01-14-2011 05:49 AM
Quatro Mba 080 NH2R furnance manual wolfden13 HVAC 1 02-10-2010 05:26 AM
Furnance question. diy4life Building & Construction 29 12-01-2009 06:39 PM
Furnance question satz HVAC 8 02-05-2009 08:44 AM
Furnance burner won't stay on. 2007ken HVAC 11 03-04-2008 12:29 AM
