RUDD Crawl Space Unit Not Turning On - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2010, 02:06 PM   #1
RUDD crawl space unit not turning on
I have a UDUD-075C-ER RUDD furnace. When I tried to turn on the heat last night it would not come on. The fan will come on in the run position. I checked the conections to the furnace and from the thermostat. Everything looks ok. I am not a professional. Just a limited handy man.
When I go to the furnace and it's in the on position to start. I hear a hum when I turn the power on. When I turn the power off it stops.
So in review.
system will not run
fan will run in run position not automatic
wires to furnace and from thermostat look good
AC does work fyi
I hear a hum when power is on to furnace
Please any help would be greatly appreciated
thank you
Paul Johnson is offline   Reply With Quote
Old 11-13-2010, 06:39 PM   #2
An old Tradesmen
Rewards Points: 6,588
Check the error code on the control board. Your inducer may be bad.
Jump the R and W at the furnace and see if it runs then when you put teh blower panel back on.
Old 11-14-2010, 11:15 AM   #3
could you explain that in a little more detail. I have no HVAC experience
thank you
Old 11-14-2010, 11:22 AM   #4
HVAC / Plumbing
thank you
Then, It may not be easy
If you have a clear sight glass on the blower panel. Look inside , you should see a small light. See if it's flashing. count the flashes. take blower door off & look on the back of that panel for the # of the flash code
kenmac is offline   Reply With Quote
Water in crawl space after it rains and other questions about crawl space. dupaloop General DIY Discussions 1 04-13-2010 06:58 AM
Crawl Space Questions (with pics) burnt03 Building & Construction 4 11-04-2009 07:44 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 04:11 PM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 09:26 PM
