Old 07-24-2011, 12:43 AM   #1
Question
RUDD Blower Will Not Shut Off
I have a Rudd Silhouette II Gas Furnace. Model # RCBA-3765AS17. The blower will not shut off and runs 24/7. Even if I turn the thermostat off, the blower continues to run. The compressors outside still cycles on and off like normal. I have tried replacing the thermostat and nothing changed. The only way to get the blower to shut off is to turn the breaker off at the power panel.
What should I check?
powerman02 is offline   Reply With Quote
Old 07-24-2011, 12:58 AM   #2
JJboy's Avatar
most like the relay at board control is stuck. you can knock the relay, maybe you're be able to release it.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-24-2011, 05:59 AM   #3
An old Tradesmen
Could be a stuck/bad high limit. This is a common thing with furnaces that are installed in an attic.
Bryant Plus 90 - No Blower Ducaticorse HVAC 11 10-16-2012 09:39 PM
York Furnance Blower Will Not Shut Off mrinck HVAC 5 02-07-2011 03:16 AM
Bryant Furnace Blower Won't Shut Off aorozco HVAC 3 12-02-2010 02:20 AM
Luxaire furnace blower will not shut off danaugstin HVAC 1 10-06-2009 10:14 PM
blower won't shut off on new gas furnace johnny67 HVAC 36 09-14-2009 10:23 PM
