RTH7500D T-stat To Heat Pump Wiring - Need Help - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2011, 09:51 PM   #1
RTH7500D t-stat to heat pump wiring - need help
Hello,
bought honeywell RTH7500D digital programmable thermostat from Amazon which is supposed to be compatible with heat pump system with auxilliary heat to replace coleman 3600-367 thermostat. furnace for mobile home is nordyne model FEH-012HA-04 [41000 BTUH].
old t-stat had terminals O,B,G,E,Y, R,X,L AND W2 with a wire on each terminal EXCEPT the E terminal. [8 wires total]
labeled and disconnected wires and then wired new t-stat per manual as follows; B wire to C terminal, G wire to G, Y wire to Y, O wire to O/B, R wire to R terminal which is jumpered to RC terminal, W2 wire to AUX, X wire to E and finally L wire to L.
installed t-stat and programmed functions 0170 to 7, 0190 to 0, 0270 to 9, 0300 to 0, and 0530 to 1
turned circuit breaker back on and nothing worked. called honeywell tech support and they reviewed my wiring and programming, said it was correct and that I had a bad t-stat. contacted Amazon and asked for a new t-stat to replace this defective new one. installed new replacement with same result - nothing works.
did continuity checks from t-stat to furnace junction box and noticed the old [X] black wire goes to transformer common. figured this wire should be going to C common on new t-stat, so moved it there.
so now what do I do with B brown wire ? already have O orange wire at O/B terminal. manual says ' if old t-stat had separate O and B wires, attach the B wire to C terminal. if another wire is attached to C terminal [my case] , stop and contact qualified contractor for help ................why I'm here.
APPRECIATE ANY HELP
AJD63 is offline   Reply With Quote
Old 02-18-2011, 10:03 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
this thermostat will not work with your system, you need one with separate o and b terminals. You have a rare system that requires this setup.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
AJD63 (02-18-2011)
Old 02-18-2011, 10:12 PM   #3
thanks for the reply. wish honeywell would have told me this.
any recommendations on t-stat with separate O + B terminals for heat pump with aux heat ?
Old 02-18-2011, 10:25 PM   #4
AKA HVACTECHFW
white rodgers 1F95-1277
WHITE RODGERS 1F85-0422
White rodgers stats typically have separate o and b terminals
IT IS WHAT IT IS
Old 02-18-2011, 10:41 PM   #5
thanks again. looked at specs and first seems best. second one actually has combined O/B terminal.
help appreciated
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
Heat Pump Control Wiring Questions IBuiltPools HVAC 3 01-14-2010 02:45 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
