RTH7500 To Goodman Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 11-17-2009, 06:00 PM   #1
Smile
RTH7500 to Goodman heat pump
I have a self contained 4 ton Goodman heat pump with 10K auxiliary heat strips. I am wanting to hook it up to a Honeywell RTH7500D thermostat. Can anyone tell me the correct wiring for this application? Thanks for the help.
mrmr56 is offline   Reply With Quote
Old 11-17-2009, 09:37 PM   #2
Houston204's Avatar
Rewards Points: 556
Post your Goodman model number.
Is the heatpump side already wired in?
Houston204 is offline   Reply With Quote
Old 11-18-2009, 05:43 PM   #3
Houston, Thanks for the reply. The Goodman model number is
GPH1348H21AB and it has an add on 10K heat coil. The color codes on the unit (not the thermostat wiring) are as follows. Yellow, Red, Green, White, Orange, Brown, and Blue. I hope this gives you enough information. Charles
Old 11-18-2009, 10:30 PM   #4
Houston204's Avatar
Rewards Points: 556
yellow = Y
red = Rc & R
green = G
white = Aux
orange = O
brown = E
blue = C
option 170 = 7
190 = 0
Old 11-19-2009, 01:48 AM   #5
Houston204's Avatar
Rewards Points: 556
10KW is kinda small. You might want to jumper Aux to E. Other than that wire as shown.
Old 11-19-2009, 06:47 PM   #6
Many Thanks for the valuable information. Everything works as it is supposed to. If I get down to Houston, I will buy you a dinner. Have a great day. Charles
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Goodman Heat Pump defrost noise RCApp HVAC 1 12-17-2008 07:54 AM
