RPJ2 Blower Fan Will Not Stop Running - HVAC - DIY Chatroom Home Improvement Forum
Old 07-17-2009, 02:24 PM   #1
Question
RPJ2 Blower fan will not stop running
I have a RPJ2 furnace which is 12 years old now. We had a storm in our our area last night with lighting which knocked our electric out momentarily. The furnace blower fan has been running none stop ever since the electric outage. I even disconnected my T-stat which is a (Honeywell RTH7400D I've had for 3 years) and the blower fan will still run without any connections to the T-stat.
I can only stop the blower by turnig the switch off at the furnace.
The A/C will run and go off via the T-stat, but the blower will go off for a second and then start running again none stop.
When I turn the blower on manually with the furnace switch, it takes about 45 seconds for the blower to come on and then it will run non stop.
Could it be a fried circuit board or a relay that is stuck, I've kind of ruled out the T-stat. I think the lighting knocked something out.
Can anyone give me some insight or help.
number22 is offline   Reply With Quote
Old 07-17-2009, 02:54 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 376
The board probably got damaged by the power surge. It is now unsafe to use for the heating cycle also. I would get a experienced Heil/ICP tech to check that furnace for safety as it has a history of cracked heat exchangers/popped compression rivets in the heat exchanger.
Old 07-17-2009, 03:31 PM   #3
Is my best fix a new fan timer control board ?
I know the comfortmaker part number is 1009838 and is fairly affordable.
Is the installation of a new fan timer control board hard to do ?
Old 07-17-2009, 03:54 PM   #4
To prevent unnecessary parts changeouts and find the root cause, post a schematic, but it does kinda' sound like damaged electronics at a minimum.
If you're in FL or the Ozarks, whole house surge protection would have spec's like these:
4000 joules, total
80,000 amps, max
Insurance, $5k per item
design lifetime 10 yrs.
Old 07-17-2009, 04:05 PM   #5
I had no idea a surge could effect my heating and cooling system like that.
Old 07-17-2009, 04:30 PM   #6
You should see what elec. surges do to some people.
And getting replacement parts is very difficult, depending on what part you fried.
Old 07-17-2009, 04:36 PM   #7
I can only imagine !!!!
Good point !!!!
Old 07-19-2009, 04:03 PM   #8
Update: after Thursdays storm and Fridays investigation. Late Friday night I was still doing the manual on /off switch thing at the furnace, after I ran a cycle I had to do a quick reset of the T-stat tempature, which put the T-stat in "Wait" mode. The blower finally cycled back in with the system and I've had no problem since.
The blowers is back to it's normal self.
I do however think the outage on Thursday really set this whole events in motion. I'm glad I waited ,and I'm glad I investigated myself to gain more knowledge.
I've since changed the air filter and cleaned the furnace/compressor unit inside and out. I've also cleaned the central A/C unit outside.
The system reminds me of a PC, it's very delicate and should be treated with care. This event has sure opened my eyes to the Heating and cooling units maintence and care.
Old 07-19-2009, 05:27 PM   #9
They could have designed a software loop that would have detected and automatically reset this condition.
From another thread I infer that the factory knows how to reset this condition. They may or may not tell you how to do it.
More complexity = more fragility. My relay-logic furnace controller has never failed or even burped, since 1992.
And it's the same in nature; lower forms of life are unharmed by doses of radiation that would kill humans outright.
Hot water won't stop running rickp47 Plumbing 8 02-19-2009 04:33 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 09:08 PM
Ruud blower keeps running jmt HVAC 1 11-22-2008 07:33 PM
furnace blower keeps running dmbrasket@hotmail.com HVAC 7 02-03-2008 03:57 PM
