Old 11-25-2007, 04:27 PM   #1
Question
RPJ II Furnace code
I have an RPJ II furnace that is about 13 years old. Periodically it calls for heat, the inducer starts, flames ignite then turns off almost immediately. The furnace then begins the cycle again and works fine. I have caught the code briefly before it cycles on again and it is 6 flashes. I have no interpretation for 6 flashes.
Any ideas?
Marlee is offline   Reply With Quote
Old 11-26-2007, 11:56 AM   #2
Thoroughbred Mopar Man
RPJ II Furnace code
Hi marlee
It sounds like you need to serviec the burners and the flame sensor on your furnace. If you are mechanically inclined this is no problem to do. If not, call the pros in for this one. Let me know and I can walk you through the process for both.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Old 11-26-2007, 08:40 PM   #3
RPJ II Furnace code
Originally Posted by #CARRIERMAN View Post
Hi marlee
Good luck
Rusty
I believe I am mechnically inclined and have used steel wool on the flame sensor each season as well as replaced the ignitor a couple times. Any direction you have would be great and then I can decide if it seems like too big a job.
Old 02-18-2010, 12:04 PM   #4
RPJ II Furnace code
I have the same exact problem - Any follow up on this?
Thanks in Advance
stwoodsus is offline   Reply With Quote
Carrier furnace help code 13 mudtruck HVAC 8 03-30-2013 04:09 PM
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-05-2012 12:21 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
