Old 01-11-2011, 08:54 PM   #1
RPJ II Comfortmaker - 1996
Heater will stop working and blow cold air. I shut off the unit for 5-10min then turn it back on and will work. LED flashes 1 time. Any ideas out there ? Already cleaned sensor. HELP
dnice is offline   Reply With Quote
Old 01-11-2011, 10:36 PM   #2
HVAC / Plumbing
Need more info. does it have vent motor, ignitor. direct ignition or pilot ??
kenmac is offline   Reply With Quote
Old 01-12-2011, 08:43 PM   #3
Your correct vent motor, ignitor
Old 01-12-2011, 08:47 PM   #4
Professional
have the heat exchanger checked outside of what is currently wrong with furnace Known for cracked heat exchangers
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-12-2011, 08:50 PM   #5
What would be avg cost to replace heat exch. ? And wouldnt the tech check that since he has been out to twice ?
Old 01-12-2011, 08:56 PM   #6
HVAC / Plumbing
Heat exchanger is the 1 st thing I check. Tech has been there twice and it still doesn't operate ??
Old 01-12-2011, 09:01 PM   #7
Yup. Suggested a new Unit ! I would be better with a parts changer !!! He mentioned that it could be a bunch of different things.
Old 01-12-2011, 09:03 PM   #8
Knowing the error code is fashing 1 red LED wouldnt that help the tech navigate to the problem ??!
Old 01-12-2011, 09:06 PM   #9
HVAC / Plumbing
If the tech knows what he's doing & has a vm,he wouldn't have to rely on error code. I've repaired many with vm B-4 they used error codes
Old 01-12-2011, 09:09 PM   #10
Sounds like I should give someone else a shot at it ! Hey KenMac thanks for your time !
Old 01-12-2011, 09:10 PM   #11
Professional
I agree kenmac. Tech out twice and not fixed and you expect him to have checked heat exchanger? and no may not have been checked if you didn't pay for HE check. some include this with diag, some don't. Should always be included with tune-up (clean and check)
IT IS WHAT IT IS
Gas furnace brands, which is better, Comfortmaker, American Standard, and Lennox? abefroman HVAC 1 11-09-2010 02:37 PM
1996 Pontiac Grand AM Instrument Cluster change turbolover Automotive Repairs 4 10-27-2010 09:38 PM
Comfortmaker blower problem rerobins HVAC 2 01-06-2010 11:38 AM
Comfortmaker furnace issue: advice on how to proceed? bill_b HVAC 5 11-09-2009 09:29 AM
'93 Comfortmaker RPJ propane furnace lifespan? Dawsonhope HVAC 5 11-21-2008 06:47 AM
