Rpj Heat Exchanger Access Panel - HVAC - DIY Chatroom Home Improvement Forum
Old 12-09-2011, 09:53 AM   #1
rpj heat exchanger access panel
I need to replace the door or the plastic part on the door that contacts the burner switch. the plastic part is broken and does not make contact. Can I purchase the part or a replacement door.
sowellte is offline   Reply With Quote
Old 12-09-2011, 06:27 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
post a pic of it and the door and door switch.
Old 12-10-2011, 08:21 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
wire nut the 2 wires leading to the door together till you can get a new one,shut power off first
plummen is offline   Reply With Quote
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Old Armstrong Heat Exchanger (Qs with Pics) steveel HVAC 9 12-03-2010 04:36 PM
Supplemental Solar Heat Panel rocketmotor HVAC 29 03-22-2010 06:31 AM
Jacuzzi tub access panel 295yards Building & Construction 10 12-22-2009 06:46 AM
Is there such a thing as a dirty heat exchanger? suthrnreject HVAC 8 01-19-2009 09:23 PM
