Old 12-23-2006, 10:02 AM   #1
Question
RPJ 2 Furnace
I have a 10 year old RPJ 2 furnace that will not heat unless I recycle the
thermostat on and off each time I want heat. I just replace the thermostat
yesterday and it still won't work right. When it works it won't run long enought to
get to the temperature I set on the thermostat.
averyds is offline   Reply With Quote
Old 12-23-2006, 11:41 AM   #2
RPJ 2 Furnace
It appears that the unit is going into lockout, and of course the most
common reason for that is a dirty flame sensor. Remove the sensor and sand it with emry cloth or 200 grit sand paper (make it look like a clean metal rod again). RE- post if this doesent cure the problem.
acefurnacefixer is offline   Reply With Quote
Old 12-23-2006, 07:30 PM   #3
RPJ 2 Furnace
I have a igniter,no pilot light?
Old 12-23-2006, 09:03 PM   #4
RPJ 2 Furnace
check for 24 VAC present at gas control valve.
Old 12-24-2006, 01:13 AM   #5
HvacWiz's Avatar
RPJ 2 Furnace
If you have a ignitor then your furnace also has a flame sensor, if this is a 90% furnace i would also check for a pluged condensate trap
HvacWiz is offline   Reply With Quote
Old 12-24-2006, 08:27 AM   #6
RPJ 2 Furnace
Very good point..this also will cause sparatic cycling
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Furnace does't start when Fan is 'auto' stepicz HVAC 2 10-18-2005 07:10 AM
