Rotate Exhaust Vent On New Propane Boiler Install? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-09-2011, 08:55 AM   #1
Rotate exhaust vent on new propane boiler install?
Hello,
I just had a new propane boiler installed which is working well, but I have one question/concern about the install.
Attached is a photo of the exhaust vent. It is oriented horizontally, so the warm air blows out sideways. I have two concerns about this.
One, it is somewhat noisy (like a hair dryer) and this seems to broadcast the noise across the property and can be heard from quite a distance, potentially annoying neighbors (though houses are fairly far apart here).
Two, some of that warm air is being blown against the siding of the house, which I noticed this morning is warm and wet (even though it is dry and very cold outside).
My first thought is, what about rotating the cap on this exhaust so it is vertical? The air would then blow upward toward the sky and downward toward the ground. Would there be a problem with this orientation?
Are there other ways to resolve this, possibly by adding a bend or other configuration to the exhaust pipe?
I will of course be asking the installer these same questions, but wanted to consult the expertise here on the boards.
Thanks!
Rotate exhaust vent on new propane boiler install?-camerazoom-20111209084031913.jpg
beagle72 is offline   Reply With Quote
Tags
airflow , boiler , exhaust
venting radiator boiler through bigger vent amakarevic HVAC 9 09-21-2011 10:43 AM
chimney liner, excuse for propane furnace upgrade? bubbler HVAC 0 09-16-2011 07:58 AM
boiler room exhaust vent vnc72 HVAC 5 08-22-2011 04:09 PM
no vent in the soffit and no room to install same aa1bflyboy Roofing/Siding 5 02-14-2011 10:44 AM
Power Vent Question for Propane Boiler Moondaddie HVAC 4 12-23-2009 07:12 PM
