Rooftop A/C / Heater Combo Blowing Air Not Cold - HVAC - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 08:26 PM   #1
rooftop A/C / Heater combo blowing air not cold
The unit I refer to in the title is 2 years old. It was blowing cold air last week and now does the same thing except the air is now not cold. on the breaker panel all breakers are ok. Are there breakers/ fuses on or sometimes by the unit itself? What recommendations should I follow in the way of a priority checklist? The thermostat settings are the same as when it last worked.
Rosdomen is offline   Reply With Quote
Old 07-08-2011, 08:29 PM   #2
Go up there and check to see if the condenser (fan and compressor) is still running.
clocert is offline   Reply With Quote
Safely Removing Water Heater Input (Cold) fizzer Plumbing 9 07-04-2011 01:09 PM
Stops blowing cold air after several hours awathen HVAC 4 06-07-2011 09:31 AM
A/C Not blowing cold air! hearmeroar874 HVAC 64 08-05-2010 11:54 PM
Leaking Water Heater (from Cold Inlet?) doesntmatter Plumbing 7 07-12-2010 10:30 PM
wiring a bathroom fan, light, heater combo on two switches zddingus Electrical 9 04-22-2010 08:48 PM
