Rooftop 2 Stage Poor Sparks - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-26-2014, 04:01 PM   #16
An old Tradesmen
Rewards Points: 7,380
Confirm that the pilot/cross over is lighting. Then check to make sure the main burner terminal on the gas valve is getting 24 volts. If both of those check out. Connect a manometer to the manifold side of the gas valve and see if you are getting gas pressure to the manifold.
Old 02-23-2014, 07:37 PM   #17
Rewards Points: 109
I investigated the unit a bit more with my inspection mirror. The spark is very strong...but wont fire at first nor second trial. FIRST STAGE
Tek1 is offline   Reply With Quote
Old 02-24-2014, 06:33 PM   #18
An old Tradesmen
Check for an obstruction in the orifice of the cross over.
XC95M thermostat setup, two or three stage? BlueBSH HVAC 1 05-27-2012 06:10 PM
Geothermal single stage vs two stage JMH18 HVAC 3 08-13-2011 09:22 AM
Is there a reason I shouldn't disable second stage heat? zootjeff HVAC 18 01-02-2011 02:23 PM
2nd stage, please veesubotee HVAC 27 03-15-2010 06:26 AM
How to confirm 2nd stage burner working? mirob HVAC 49 12-29-2008 06:11 PM
