Rooftop 2 Stage Poor Sparks - HVAC - DIY Chatroom Home Improvement Forum
Old 01-12-2014, 07:57 AM   #1
Rewards Points: 109
rooftop 2 stage poor sparks
Unit sparks for 3 seconds on first trial. Wont lit. No voltage output from the two modules. But 27v going to them.
Tek1 is offline   Reply With Quote
Old 01-12-2014, 03:03 PM   #2
Rewards Points: 109
Blows cold air
Old 01-12-2014, 05:31 PM   #3
An old Tradesmen
Rewards Points: 7,816
Is it direct ignition, or does it light a pilot.
Always post brand and model number.
Old 01-12-2014, 07:00 PM   #4
Rewards Points: 109
Old 01-12-2014, 07:00 PM   #5
Rewards Points: 109
Direct ignition
Old 01-12-2014, 09:56 PM   #6
An old Tradesmen
Ah, the same one that the blower won't shut off.
That should light a pilot/cross over first, that lights all the burners.
Cross over may be lighting, but not main burners. or, could have a restriction in the orifice of the cross over.
I usually take a flame mirror and look at the spark to make sure its sparking at the ignitor.
Old 01-12-2014, 10:31 PM   #7
Rewards Points: 109
Its two units up there...this one wont ignite
Old 01-12-2014, 10:59 PM   #8
An old Tradesmen
Use a flame mirror to see if the cross over is lighting. if it is, the module may be bad.
Old 01-13-2014, 10:08 AM   #9
Rewards Points: 109
They are 2 modules and two gas valves
Old 01-13-2014, 10:09 AM   #10
Rewards Points: 109
I dont think the cross over is lighting
Old 01-13-2014, 10:20 AM   #11
Rewards Points: 109
I forgot to mention after 7-10 minutes it retrials but sparks for a little longer then came on. 3rd times that happens
Old 01-13-2014, 03:56 PM   #12
An old Tradesmen
Yep, standard set up for a York 2 stage RTU.
Not unusual for 1 of the burners to not have been working for sometime. And no one complains about poor/no heat until the other burner goes down also.
Did you inspect the heat exchanger yet to see if it is cracked/rusted through at the seams. Which is typical for a York gas/electric RTU.
Old 01-13-2014, 10:49 PM   #13
Rewards Points: 109
I will check.
Old 01-16-2014, 04:53 PM   #14
Rewards Points: 109
I replaced the modules n its been running. Will check main burner next week.
The Following User Says Thank You to Tek1 For This Useful Post:
beenthere (01-16-2014)
Old 01-26-2014, 03:41 PM   #15
Rewards Points: 109
Main burner not coming on
XC95M thermostat setup, two or three stage? BlueBSH HVAC 1 05-27-2012 06:10 PM
Geothermal single stage vs two stage JMH18 HVAC 3 08-13-2011 09:22 AM
Is there a reason I shouldn't disable second stage heat? zootjeff HVAC 18 01-02-2011 02:23 PM
2nd stage, please veesubotee HVAC 27 03-15-2010 06:26 AM
How to confirm 2nd stage burner working? mirob HVAC 49 12-29-2008 06:11 PM
