Old 12-20-2012, 04:32 PM   #1
roof top heater/gas furnace
hello I thank and appreciate the help
my heater just stopped working one day and noticed that the air filter was bad, after replacing it i pushed the reset button ,t but to no luck.. all it makes is a humming noise..
jautery is offline   Reply With Quote
Old 12-20-2012, 05:16 PM   #2
Can you be a litlle more specific what heater or furnance are you using ? If it is electric heater, a blocked filter can cause overheating and damage something if the overheat protection switch is not working. A gas furnance may not have the same result with the blocked filter.
DIY_user is offline   Reply With Quote
Old 12-21-2012, 08:23 AM   #3
Does the humming sound seem to be coming from the blower assembly?
If Gas furnace Do the burners light?
If Gas furnace do you have a sprak ignition, hot surface (Glow coil) ignition, or standing pilot?
The people on this forum who can help will need some more information.
oncall is offline   Reply With Quote
Tags
heater
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Need opinion on this roof profenx Roofing 14 10-12-2010 01:56 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
