Old 03-09-2012, 11:12 AM   #1
Roof Penetrations in flat roof for lineset/whip
I am putting two 2-ton heat pump units on a new construction flat roof. The lineset will be 3/4" suction and 3/8" liquid and the whip will be 8 gauge. The roofers are coming soon and requested that I put the penetrations in. I have not decided on a HVAC installer but want to make sure that I leave a viable penetration for whomever I do hire.
My plan was to place a 3" rubber flashing boot and a 3" PVC vertical pipe with a 180-degree elbow (similar to my vent stack penetrations) to keep water out for each unit. My questions are these.
1. Can the lineset and whip be run through a single PVC and then sealed post-HVAC installation with spray foam? Or do I need a separate penetration for each?
2. Should I put in metal flashing vs a rubber version?
Thanks in advance!
mrc333 is offline   Reply With Quote
Old 03-09-2012, 02:30 PM   #2
An old Tradesmen
The method you want to do is fine. As long s you run the lines at the same time.
Which ever flashing your roofers prefer.
Tags
flashing, hvac, roof penetration
Flat Roof Repair Costs Pittsville Roofing 10 09-04-2012 12:50 AM
Blown Insulation - Flat roof AndrewF Roofing 1 12-31-2009 07:41 PM
large leaking tar flat roof erbilliards Roofing 2 03-16-2008 12:59 PM
Flat Roof Suggestion gladiator Roofing 3 09-14-2005 04:31 PM
Where flat roof meets shingled roof bstyer Roofing 1 07-07-2005 09:34 PM
