Roof Ductwork Insulation - HVAC - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 03:59 PM   #1
I am buying a house that has a built up roof and the AC unit is on top of the roof. All the duct work is on the roof as well. None of the ducts are insulated and you could just about fry an egg on them in the summer. I'm pretty sure this isn't very efficient.
I am wondering what options I have for insulating them myself. I've googled it a lot and come up with answers for indoor ducts rather than outdoor.
A roofer quoted me 3000 dollars to spray foam insulation on it.
The house is only 1300 square feet...this leaves about 6 ducts off the AC unit on the roof.
One site said to use Duct Insulation - R-6.0 around it but I'm not sure that's good for exterior insulation. Any suggestions would be helpful. I don't mind doing the work myself.
Here is a picture of the roof, if it helps.
Thanks a bunch.
beeceee is offline   Reply With Quote
Old 08-08-2011, 11:20 AM   #2
Hey there, I guess I had originally posted into the wrong section of the forum and it probably fell to far down on the list for some to read so I'm replying.
Any help with this would be appreciated. I live in Phoenix and will be moving into this house within the next 2 weeks. thanks!
Old 08-08-2011, 11:36 AM   #3
Experienced
Jackofall1's Avatar
Welcome Beeceee, to the best darn DIY'r site on the web.
In a brief search I have come up with this
http://www.tvmi.com/prod_detail.php?...=&a=&am=&p=217
There are many more options I am sure.
Mark
Old 08-08-2011, 11:51 AM   #4
Thanks! How I did not find this is beyond me. I was searching all day. :|
Thanks so much, I will check this out
Old 08-08-2011, 02:26 PM   #5
Thanks a bunch.
I think one of the best products for hard to reach and insulate areas is a spray foam insulation product. Not only is it very efficient and cost-effective, but it is a "green" product as well. It also has a high "R" value too. We did our house a few months ago and even the A/C is on less often. I even find that it works well as a soundproofing material :-)
We used a product called foam-it Green (http://www.sprayfoamdirect.com/). I hope you find that useful. :-)
FrancisABoyd is offline   Reply With Quote
Old 08-08-2011, 05:16 PM   #6
Are you sure that duct work does not have an insulated liner?
Shed roof addition & insulation qustion radgumbo Roofing/Siding 2 12-06-2010 05:33 AM
Adding insulation to a low-slope roof cbeingessner Roofing/Siding 25 09-21-2010 11:01 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Add insulation to solid timber roof justinNC Building & Construction 2 11-01-2009 12:16 PM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 08:24 AM
