Rod That Can Make A 90 Deg Turn To Push Open A Damper?? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 09:16 PM   #1
Rewards Points: 184
Rod that can make a 90 deg turn to push open a damper??
I have a damper that vibrates closed, from the vent its about 1.5 feet in then it makes a 90 degree turn and then damper is about 3 feet down from there.
Whats the best way to knock that open? Some kind of flexible rod I'd imagine.
I can reach my hand in all the way to the 90 deg turn, but then have about more feet to go.
abefroman is offline   Reply With Quote
Old 03-13-2013, 11:37 AM   #2
Id think that the cheapest most convenient thing would be to get a metal clothes hanger and straighten it out then fold it in half. Should give you something flexible enough to get through the 90 but strong enough to push the damper open. Metal hangers have so many uses!
ahrens is offline   Reply With Quote
Old 03-13-2013, 11:45 AM   #3
Rewards Points: 184
I'm not sure if that would be long enough.
What about a piece of soft copper piping?
Old 03-16-2013, 08:25 PM   #4
is it in a finished ceiling space ?
hvac dude is offline   Reply With Quote
Old 03-16-2013, 08:53 PM   #5
Rewards Points: 184
It is.
Old 03-16-2013, 09:20 PM   #6
Roofmaster
Rewards Points: 2,210
Can you explain this a little better? Why dont you go into the attic and put a spring on it? Are you going to reach in and push it open every time it vibrates closed?
Old 03-16-2013, 09:27 PM   #7
Rewards Points: 184
No attic, its in a condo.
Old 03-18-2013, 11:24 PM   #8
does the blade move freely ? if you were to get something in there ?
Old 03-19-2013, 03:40 AM   #9
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Wonder if a sewage pipe inspection camera could work. You can shove all sorts of stuff down there but you kind of need to see what's happening too. Might be able to just push it with the camera.
Red Squirrel is online now   Reply With Quote
Sizing Window AC For Open Room appleye1 HVAC 17 07-29-2010 10:00 AM
Zoning question spyder24 HVAC 23 04-03-2010 07:12 PM
how to make 90 turn of 4" dryer vent in 2x4 wall hohadcr HVAC 5 03-15-2010 09:59 PM
Damper for Microhood - Make my own? getinmybelly HVAC 0 01-27-2010 10:04 AM
Why does the faucet make a *thump* when I turn the water on? JayBird Plumbing 1 10-03-2009 07:53 PM
