RobertShaw Thermostat Fan Stuck On - HVAC - DIY Chatroom Home Improvement Forum
Old 03-08-2014, 01:19 AM   #1
DDJ
RobertShaw thermostat fan stuck on
Can anyone help? My programmable thermostat fan is stuck on. The switch is in the "off" position. I took out the batteries and the fan is still on. The ac/heatpump is on the roof. Should I just replace the thermostat?
DDJ is offline   Reply With Quote
Old 03-08-2014, 05:26 AM   #2
An old Tradesmen
Rewards Points: 6,060
If the fan auto/on switch is stuck in the on position. Yes, time for a new thermostat.
Old 03-08-2014, 10:49 AM   #3
Rewards Points: 1,192
Maybe the fan relay?
bobelectric is offline   Reply With Quote
Old 03-08-2014, 11:20 AM   #4
DDJ
How would I know if it is the relay switch or the thermostat needs to be replaced? Where is the relay switch? If I replace the thermostat, will that also fix the relay switch?
Old 03-08-2014, 11:56 AM   #5
chitownken's Avatar
Rewards Points: 510
Disconnect the red wire from the thermostat. If the fan stops running, the thermostat is bad. If the fan still runs, then the fan relay, controlboard, or wiring is suspect.
chitownken is offline   Reply With Quote
The Following User Says Thank You to chitownken For This Useful Post:
DDJ (03-08-2014)
Old 03-08-2014, 12:33 PM   #6
DDJ
My electricity was recently turned off for another project. Could this have caused the fan to be stuck on?
Old 03-08-2014, 01:08 PM   #7
DDJ
Robertshaw thermostat
I disconnected the red wire from the thermostat and the fan is still running. Where is the relay switch and how would I test it?
Old 03-08-2014, 02:27 PM   #8
chitownken's Avatar
Rewards Points: 510
The fan relay and control board will be in the air handler. The next step is to remove the red wire at the air handler. If the fan doesn't run, then the thermostat wiring has been shorted. If the fan still runs, then you will need to provide the make and model of the air handler. Do you have a multimeter?
Old 03-08-2014, 02:57 PM   #9
An old Tradesmen
Ah, so the fan switch is not "stuck on", its just your fan keeps running.
Could be the relay is stuck/burnt fast, or the limit is tripped. You need a multimeter. And then need to go on roof and check.
Old 03-09-2014, 01:58 AM   #10
DDJ
I will get a multimeter and check on the roof.
Old 03-09-2014, 10:57 AM   #11
chitownken's Avatar
Rewards Points: 510
Is it a package unit? Or does it have an air handler inside the house with the heat pump outside unit on the roof? Where you need to check is wherever the blower motor is located. Hate to see you up on the roof for nothing.
Old 03-10-2014, 10:19 AM   #12
DDJ
I think it a package unit. I will ask if someone can come over and help me check these things and post a reply. Thank you
Thermostat issue, need help JonMio HVAC 2 02-11-2012 08:35 AM
Thermostat issue, need help JonMio Electrical 1 02-10-2012 04:40 PM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
