Robertshaw 9500 - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 10:13 AM   #1
Robertshaw 9500
I have renters that keep turning the heat off during winter and cause freeze damage to the pluming. Is there a way to make a Robertshaw 9500 only allow the temperature go so low even if the renters try to turn it 'Off' or to 'Cool' (which turns the heat off)?
John626 is offline   Reply With Quote
Old 10-22-2011, 10:31 AM   #2
Put the thermostat in a lock box or add an addendum to the lease that requires the tennant to maintain a minimum temperature in the winter and if they don't, they will be billed for damages...
jfrotten is offline   Reply With Quote
Old 10-22-2011, 04:03 PM   #3
how
Rewards Points: 1,104
I've had landlords put in an additional second thermostat and lines to a location within the building envelope that the tenents don't have access to with it set to a minimum temp when faced with ignorant or belligerent attitudes.
how is offline   Reply With Quote
Old 10-22-2011, 05:12 PM   #4
There are a couple of thermostats that have freeze guards built-in. They will automatically turn on when the temp hits 40. I don't know the make or model though..I think its a rite temp.
Master of Cold is offline   Reply With Quote
Old 10-22-2011, 09:24 PM   #5
Robertshaw 9500 has built-in freeze protection set at 40*. You can search for "construction thermostat" wire into your thermostat wire place it in the return plenum so it can't be tampered with by the renters. They are preset to 65* and non adjustable.
thestig3 is offline   Reply With Quote
Frustrated: switching from robertshaw 8625 thermostat to hunter 4155c jrob514 HVAC 4 04-11-2011 11:24 PM
Converting Robertshaw Gas Valve 7100 DER-S7C mikefrommi HVAC 9 03-08-2011 12:46 PM
Honeywell to Robertshaw eh97ac HVAC 3 02-09-2011 02:14 PM
Troubleshooting Robertshaw Ignition milkshake36 HVAC 4 09-28-2009 10:49 AM
Wiring a RobertShaw 9870i to Gas Furnace & Heat Pump jerfer HVAC 11 12-21-2008 09:09 PM
