Rigid Foam Sheathing On Top Of Foam Insulation? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2009, 10:33 PM   #1
Rewards Points: 508
Question
Rigid foam sheathing on top of foam insulation?
Can you think of any reason why I wouldn't want to use rigid foam insulation in my exterior wall cavities if I'm replacing my wood lap siding with rigid foam sheathing?
On a different note, has anyone had any experience with Hardiplank over foam sheathing?
benjamincall is offline   Reply With Quote
Old 01-26-2009, 10:53 PM   #2
JohnH1's Avatar
Is that nat gas or LP. Wrong forum this is HVAC
JohnH1 is offline   Reply With Quote
Old 01-27-2009, 12:35 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
I really dont understand your question .Your going to remove the existing lap siding?Is there sheathing under that?you want to put ridged foam inbetween the studs?You can put hardie over foam but a better way would be to install the foam then a house wrap then vertical furring strips then your siding
Tom Struble is offline   Reply With Quote
Old 01-27-2009, 08:08 AM   #4
Yes, vertical strapping for a rainscreen. All the siding manufacturers highly recommend it. I would especially think it was important over a semi-impermeable surface like foam.
Josh Jaros
jaros bros. is offline   Reply With Quote
Old 01-27-2009, 10:06 AM   #5
tk03's Avatar
Rewards Points: 150
I may be wrong here but I thought you could not put foam inside the structure. It had to be on the exterior of the structure due to fumes in case of fire. Check with codes or better builders in the area.
tk03 is offline   Reply With Quote
Old 01-28-2009, 09:50 AM   #6
as long as the foam is protected by drywall its ok im just not sure why the op want to put foam panels in between the stud bays
Old 02-03-2009, 11:01 AM   #7
Rewards Points: 508
You're not sure why I would want the foam in the stud bays as opposed to fiberglass batts in the bays?
Old 02-03-2009, 11:03 AM   #8
Rewards Points: 508
No sheathing is present under the lap siding at this point. I was thinking rigid foam sheathing and rigid foam insulation in the stud bays. I think I'll take your advice on the furring strips.
Old 02-03-2009, 11:11 AM   #9
Rewards Points: 508
LP of course. I figured the folks who are experienced at heat load calculations might have some input on how to best maintain the house envelope.
Old 02-03-2009, 11:20 AM   #10
oh i think i understand your going to remove the existing siding and that is also the sheathing.you have to be careful when you remove the siding your reducing racking resistance depending on how your house is built you would want to replace it with a structural panel imo.why dont you consider blowing cellulose or fiberglass into your walls leave the lap siding and installing a foam sheathing on top of the siding then tyvek then your furring and finally your siding this would be a more typical installation .There are foam wraps that are perforated to help the wall ''breathe better''usually these are the fanfold types usually 1/2 thick
Old 02-03-2009, 04:12 PM   #11
JohnH1's Avatar
As I see you are correct. I have been following the thread and have learned a few things. Glad you posted here.
Old 02-03-2009, 09:39 PM   #12
Rewards Points: 508
I'll definitely consider that route. If I leave the siding in place, wouldn't I be likely to see some unevenness in the Hardiplank?
Old 02-04-2009, 01:41 AM   #13
thats another advantage to useing vertical strapping you can shim it to help keep your siding looking straighter
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
Using rigid foil faced foam insulation Ronnie1a Remodeling 1 01-22-2008 02:23 PM
Best Ext. Sheathing: Rigid Foam An Option? austinbirdman Building & Construction 3 12-15-2006 10:02 AM
Rigid foam as floor insulation rkhpapa Building & Construction 3 09-24-2006 07:06 PM
