Rigid Duct Insulation Alternative - HVAC - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 06:34 AM   #1
Rewards Points: 280
Just had my first experience wrapping rigid duct with foil faced fiberglass duct wrap. Don't know how you guys do it but there must be a real learning curve to wrapping around 45 and 90 degree pipe.
So, maybe I read it here or elsewhere, but I seem to recall someone mentioning using flex duct to insulate rigid pipe.
Does it work? If so, can you keep the inner wire and plastic liner in place or should it be removed?
I'm replacing some flex with rigid so the flex will be headed to the landfill if not re-used.
Earnie is offline   Reply With Quote
Old 01-11-2010, 10:26 AM   #2
Wrap the trunk and use sleeves on the hard pipe. Staple then tape the seams on the duct wrap.
SKIP4661 is offline   Reply With Quote
Old 01-11-2010, 02:15 PM   #3
sktn77a's Avatar
Rewards Points: 392
I guess, theoretically, you could use flexduct to wrap ROUND metal ducts. But it would probably be more expensive than regular duct wrap.
sktn77a is offline   Reply With Quote
Old 01-11-2010, 03:13 PM   #4
An old Tradesmen
Rewards Points: 7,412
More expensive material wise.
But faster labor wise.
Old 01-13-2010, 08:13 PM   #5
Rewards Points: 280
After some hunting today I found a local HVAC company that had R8 flex in stock. Yes, extra cost and a bit of a waste removing the plastic inner air duct but using just the outer insulation sleeve is going to make my project so much easier.
Thanks.
Old 01-13-2010, 08:30 PM   #6
An old Tradesmen
If you get the next size bigger flex. It slides right over the hard pipe.
Old 01-13-2010, 09:06 PM   #7
Leave the liner in it to start Earnie. Pulling just the insulation over a pipes sharp edge without the plastic "guts" is a pain in the behind. Goes much faster if you put the guts over the pipe end then pull from there.
AC Flex Duct - Suspend above attic insulation or lay it on top? fritzycat1 HVAC 13 08-17-2011 10:19 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
super insulation retrofit with rigid insulation hostaking Building & Construction 5 01-07-2009 10:23 AM
Q's about duct insulation veesubotee HVAC 3 12-13-2008 03:44 PM
Rigid insulation question Endeavor General DIY Discussions 2 07-17-2007 10:27 AM
